Problem: AD5372 Output always 0V
Question asked by GHegi on Feb 2, 2015
Latest reply on Feb 19, 2015 by GHegi
I’m using an evaluation board for the AD5372 DAC-chip, with which I have the
following problem:
I measured the outputted voltages using an oscilloscope, but no matter which
command I send to the EVAL-board the output is always 0 V. The commands are
send to the chip via USB with a self written LabView program using the DLL for
this DAC family and the supplied USB driver.
So, I’ve measured the commands the chip receives with the oscilloscope and they
appear to be fine according to the specs/command document. Also, the specified
supply voltages are present (5 V, +- 16 V). Further, I’ve set/unset RESET as
specified and made sure that CLR is not active. But it still will only give me
0 V.
Do you have any idea what I still could try? And/or why this problem might
occur?
Thanks in advance for any help!
GHegi
