ADXL362 basic questions
Question asked by igor@tigaro.com on Jan 31, 2015
Latest reply on Feb 9, 2015 by neilzhao
Hello
We are trying to incorporate motion detection into our system with the help of ADXL362.
I am not able to get correct X/Y/Z values in self test mode or any other (I am able to read the values but they are always 0).
The strange thing is that while manufacture ID is ok, and REVID is 0x02, the PARTID is always read as 0 which contradicts data sheet.
Why this can happen? May be this can explain malfunction of ADXL?
Also we use the following configuration:
// Disable FIFO
  AccelWriteReg(FIFO_CONTROL, 0);
  //  Set an activity threshold
  AccelWriteReg(THRESH_ACT_H, 0);
  AccelWriteReg(THRESH_ACT_L, 15);
  val = AccelReadReg(THRESH_ACT_L);
  AccelWriteReg(TIME_ACT, 0);
  // Setup inactivity threshold
  AccelWriteReg(THRESH_INACT_L, 105);
  val = AccelReadReg(THRESH_INACT_L);
  AccelWriteReg(THRESH_INACT_H, 0);
  // Setup inactivity detection to be 2 sec
  AccelWriteReg(TIME_INACT_H, 0);
  AccelWriteReg(TIME_INACT_L, 37);
  val = AccelReadReg(TIME_INACT_L);
  // Enable interrupt on transition change
  AccelWriteReg(INTMAP1, 0xF1);
  val = AccelReadReg(INTMAP1);
  // 2G @ 12.5 Hz
  AccelWriteReg(FILTER_CTL, 0);
  // Setup power control: enable AUTOSLEEP
  AccelWriteReg(POWER_CTL, 0x02);
  // Enable activity/inactivity in loop mode
  AccelWriteReg(ACT_INACT_CTL, 0x37);
  val = AccelReadReg(ACT_INACT_CTL);
        while (1)
            status = AccelReadReg(STATUS);
            pin = GPIO_PinRead(ACCEL_ISR_PORT, ACCEL_EXTI_PIN);
            osDelay(1000);
The status is always read as 0x40 or 0x41...So no activity or inactivity is ever detected...
Thanks
Igor
