AD9361 charge pump calibration
Question asked by lior on Jan 28, 2015
Latest reply on Feb 10, 2015 by lior
I’m in a bring up process of a new board with the AD9361, I’m seeing the following behaviors after sending the script on the bottom.
What’s work well is:
  1. SPI interface
  2. clk_out signal
  3. Data_clk signal
  4. BBPLL lock, Done when 0x05E[7]==1
What’s Does not work is:
  1. No data coming out from the AD936, even when I enable loop mode 0x3F5[0]<=1 , while data is being sent in the Tx direction.
  2. ENSM stuck in state 4.
  3. Wait for Charge Pump calibration never complete (Done stays low 0x244[7]==0 or 0x284[7]==0 ).
The only difference from the AD9361 evaluation bord is that the VDD_GPO is connected to 1.3V instead of 3.3V.
I have no idea how to proceeds, any have?
BlockWrite          2,6          // Set ADI FPGA SPI to 20Mhz
SPIWrite              3DF,01
ReadPartNumber
SPIWrite              295,14   // Power up XO path (Default)
SPIWrite              2A6,0E  // Enable Master Bias
SPIWrite              2A8,0E  // Set Bandgap Trim
REFCLK_Scale    40.000000,1,2     // Sets local variables in script engine, user can ignore
SPIWrite              292,08   // Set DCXO Coarse Tune[5:0]
SPIWrite              293,80   // Set DCXO Fine Tune [12:5]
SPIWrite              294,00   // Set DCXO Fine Tune [4:0]
SPIWrite              2AB,07  // Set RF PLL reflclk scale to REFCLK * 2
SPIWrite              2AC,FF  // Set RF PLL reflclk scale to REFCLK * 2
SPIWrite              009,07   // Enable Clocks
WAIT     20           // waits 20 ms
// Set BBPLL Frequency: 983.040000
SPIWrite              045,00   // Set BBPLL reflclk scale to REFCLK /1
SPIWrite              046,03   // Set BBPLL Loop Filter Charge Pump current
SPIWrite              048,E8   // Set BBPLL Loop Filter C1, R1
SPIWrite              049,5B   // Set BBPLL Loop Filter R2, C2, C1
SPIWrite              04A,35  // Set BBPLL Loop Filter C3,R2
SPIWrite              04B,E0   // Allow calibration to occur and set cal count to 1024 for max accuracy
SPIWrite              04E,10   // Set calibration clock to REFCLK/4 for more accuracy
SPIWrite              043,29   // BBPLL Freq Word (Fractional[7:0])
SPIWrite              042,5C   // BBPLL Freq Word (Fractional[15:8])
SPIWrite              041,12   // BBPLL Freq Word (Fractional[23:16])
SPIWrite              044,18   // BBPLL Freq Word (Integer[7:0])
SPIWrite              03F,05   // Start BBPLL Calibration
SPIWrite              03F,01   // Clear BBPLL start calibration bit
SPIWrite              04C,86   // Increase BBPLL KV and phase margin
SPIWrite              04D,01  // Increase BBPLL KV and phase margin
SPIWrite              04D,05  // Increase BBPLL KV and phase margin
WAIT_CALDONE               BBPLL,2000         // Wait for BBPLL to lock, Timeout 2sec, Max BBPLL VCO Cal Time: 345.600 us (Done when 0x05E[7]==1)
SPIRead               05E         // Check BBPLL locked status  (0x05E[7]==1 is locked)
SPIWrite              002,DC  // Setup Tx Digital Filters/ Channels
SPIWrite              003,DC  // Setup Rx Digital Filters/ Channels
SPIWrite              004,03   // Select Rx input pin(A,B,C)/ Tx out pin (A,B)
SPIWrite              00A,15  // Set BBPLL post divide rate
// Setup the Parallel Port (Digital Data Interface)
SPIWrite              010,C8   // PPORT Config 1
SPIWrite              011,00   // PPORT Config 2
SPIWrite              012,02   // PPORT Config 3
SPIWrite              006,0F   // PPORT Rx Delay (adjusts Tco Dataclk->Data)
SPIWrite              007,00   // PPORT TX Delay (adjusts setup/hold FBCLK->Data)
// Setup AuxDAC
SPIWrite              018,00   // AuxDAC1 Word[9:2]
SPIWrite              019,00   // AuxDAC2 Word[9:2]
SPIWrite              01A,00  // AuxDAC1 Config and Word[1:0]
SPIWrite              01B,00   // AuxDAC2 Config and Word[1:0]
SPIWrite              023,FF   // AuxDAC Manaul/Auto Control
SPIWrite              026,00   // AuxDAC Manual Select Bit/GPO Manual Select
SPIWrite              030,00   // AuxDAC1 Rx Delay
SPIWrite              031,00   // AuxDAC1 Tx Delay
SPIWrite              032,00   // AuxDAC2 Rx Delay
SPIWrite              033,00   // AuxDAC2 Tx Delay
// Setup AuxADC
SPIWrite              00B,00   // Temp Sensor Setup (Offset)
SPIWrite              00C,00   // Temp Sensor Setup (Temp Window)
SPIWrite              00D,03  // Temp Sensor Setup (Periodic Measure)
SPIWrite              00F,04   // Temp Sensor Setup (Decimation)
SPIWrite              01C,10   // AuxADC Setup (Clock Div)
SPIWrite              01D,01  // AuxADC Setup (Decimation/Enable)
// Setup Control Outs
SPIWrite              035,00   // Ctrl Out index
SPIWrite              036,FF   // Ctrl Out [7:0] output enable
// Setup GPO
SPIWrite              03A,27  // Set number of REFCLK cycles for 1us delay timer
SPIWrite              020,00   // GPO Auto Enable Setup in RX and TX
SPIWrite              027,03   // GPO Manual and GPO auto value in ALERT
SPIWrite              028,00   // GPO_0 RX Delay
SPIWrite              029,00   // GPO_1 RX Delay
SPIWrite              02A,00  // GPO_2 RX Delay
SPIWrite              02B,00   // GPO_3 RX Delay
SPIWrite              02C,00   // GPO_0 TX Delay
SPIWrite              02D,00  // GPO_1 TX Delay
SPIWrite              02E,00   // GPO_2 TX Delay
SPIWrite              02F,00   // GPO_3 TX Delay
SPIWrite              261,00   // Set Rx LO Power mode
SPIWrite              2A1,00  // Set Tx LO Power mode
SPIWrite              248,0B   // Enable Rx VCO LDO
SPIWrite              288,0B   // Enable Tx VCO LDO
SPIWrite              246,02   // Set VCO Power down TCF bits
SPIWrite              286,02   // Set VCO Power down TCF bits
SPIWrite              249,8E   // Set VCO cal length
SPIWrite              289,8E   // Set VCO cal length
SPIWrite              23B,80   // Enable Rx VCO cal
SPIWrite              27B,80   // Enable Tx VCO cal
SPIWrite              243,0D  // Set Rx prescaler bias
SPIWrite              283,0D  // Set Tx prescaler bias
SPIWrite              23D,00  // Clear Half VCO cal clock setting
SPIWrite              27D,00  // Clear Half VCO cal clock setting
SPIWrite              015,04   // Set Dual Synth mode bit
SPIWrite              014,05   // Set Force ALERT State bit
SPIWrite              013,01   // Set ENSM FDD mode
WAIT     1              // waits 1 ms
SPIWrite              23D,04  // Start RX CP cal
WAIT_CALDONE               RXCP,100             // Wait for CP cal to complete, Max RXCP Cal time: 460.800 (us)(Done when 0x244[7]==1)
SPIWrite              27D,04  // Start TX CP cal
WAIT_CALDONE               TXCP,100             // Wait for CP cal to complete, Max TXCP Cal time: 460.800 (us)(Done when 0x284[7]==1)
