AD5754R DAC ISsue with STM32F3xx
Question asked by franck.eudaric@arturia.com on Jan 20, 2015
Latest reply on Sep 2, 2015 by wentworth
I'm using an STM32F302 to pilot DAC AD5724R by SPI.
I'm also using the EVAL -AD5754REBZ.
The STM32F3xx SPI2 is 16-bit frame. So no other way as my source is a 32-bit word I send 32 clocks and 2x16-bits (endian mode).
As far I understand the AD5754R needs exactly 24 clocks. So instead of using the DAC A voltage output I used the SDO serial output pin to get my voltage as Datasheet said:
Jumpers configuration is as followed:
Reference
Jumper
Function
LK1
A
REFIN chosen
LK2
Close
This link connects the VOUTA output of the AD5754R to the VIN0 input of the on-board ADC (AD7323):  When inserted, the voltage at the VOUTA pin can be read back to the PC.  When removed, the voltage at the VOUTA pin is disconnected from the on-board ADC input.
LK3
Close
This link connects the VOUTB output of the AD5754R to the VIN1 input of the on-board ADC (AD7323):  When inserted, the voltage at the VOUTB pin can be read back to the PC.  When removed, the voltage at the VOUTB pin is disconnected from the on-board ADC input.
LK4
Close
This link connects the VOUTC output of the AD5754R to the VIN2 input of the on-board ADC (AD7323):  When inserted, the voltage at the VOUTC pin can be read back to the PC. When removed, the voltage at the VOUTC pin is disconnected from the on-board ADC input.
LK5
Close
This link connects the VOUTD output of the AD5754R to the VIN3 input of the on-board ADC (AD7323):  When inserted, the voltage at the VOUTD pin can be read back to the PC. When removed, the voltage at the VOUTD pin is disconnected from the on-board ADC input.
LK6
A
USB port selected as the 5 V digital circuitry power supply source.
LK7
B
Position B selects the evaluation board to be controlled by the external source J8.
LK8
B
This link selects the digital supply voltage value for the AD5754R and the on-board ADC (AD7323): +3.3V  chosen.
LK9
B
This link selects the negative supply voltage:
Position B selects the AVSS connection of J9 as the negative supply voltage (bipolar operation).
LK10
Open
This link connects the voltage reference input of the on-board ADC to the selected voltage reference source.
LK11
Open
LDAC pin is pulled to DVCC through a 10 kΩ resistor. LDAC
LK12
Open
CLR pin is pulled to DVCC through a 10 kΩ resistor. CLR
LK13
Open
This link sets the state of the BIN/pin (LK7 must be in Position B): the BIN/pin is pulled to DVCC through a 10 kΩ resistor.
I first send the output range for DAC A to be +/- 5V sending 0x00080003.
Then I power up DAC A sending 0x00100001
Then I send my data 0x0000FFFF and then 0x00000000.
I expected a square waveform moving from +5V to -5V
Here what I've got!!!
Yellow: MOSI / Green: Clock/  Pink: CS=SYNCn / Violet: SDO
I don't understand where is my mistake as there should be one!
Many thanks for your help.
