BF518 problem with UART in DMA mode
Question asked by marco55 on Jan 16, 2015
Latest reply on Mar 23, 2015 by SachinV
I have a problem with UART in DMA mode on a Blackfin 518F.
I have to communicate with a IR reader that has a simple serial interface (baudrate 9600, 8 data bits, no parity, 1 stop bit): I have to send a single byte with value "1" to read the data, and the reply of the IR reader consists of 2 bytes.
I'm using UART0 in DMA mode and I send the read command every 100 ms. The reply arrives within 10 - 15 ms.
The problem is that after some time it happens that the two bytes are read in the opposite order: I suppose that actually I read the second byte of a message plus the first byte of the following message. After some time again the two bytes "exchange" oder, and so on.
How can I avoid this error?
adi_int_SICSetIVG(ADI_INT_DMA8_UART0_RX, 10);//Default priority
adi_int_SICSetIVG(ADI_INT_DMA9_UART0_TX, 10);//Default priority
register_handler(ik_ivg10,Uart0_ISR);//DMA8 - DMA9 (Uart0 Rx/Tx)
adi_int_SICEnable(ADI_INT_DMA8_UART0_RX);
adi_int_SICEnable(ADI_INT_DMA9_UART0_TX);
*pPORTG_MUX = 0x0400;
*pPORTG_FER = 0x0600;
*pPORTGIO_DIR = 0x9980;
*pPORTGIO_INEN = 0x6000;
*pPORTGIO_POLAR = 0x0000;
*pPORTGIO_EDGE = 0x6000;
*pPORTGIO_BOTH = 0x0000;
*pPORTGIO_MASKA = 0x0000;
*pPORTGIO_MASKB = 0x6000;
*pDMA8_CONFIG = FLOW_STOP | WDSIZE_8 | DI_EN | SYNC | WNR;
*pDMA9_CONFIG = FLOW_STOP | WDSIZE_8 | DI_EN | SYNC;
Uart0Divider = Se2112Fsclk / (16 * UartBaud);
ssync();
*pUART0_LCR |= DLAB;
*pUART0_DLL = (unsigned char)Uart0Divider;
*pUART0_DLH = (unsigned char)(Uart0Divider >> 8);
*pUART0_LCR &= (~DLAB);
*pUART0_MCR = 0;
*pUART0_GCTL = UCEN;
*pUART0_LCR = UART0_NUM_DATA_BIT_8;
//Polling in Main()
if(WriteUart0)
     SendUart0Data((unsigned char*)&Uart0TxBuffer[0],Uart0TxBuffLen);
     while(!Uart0TxOk);
     ReceiveUart0Data((unsigned char*)&Uart0RxBuffer[0],(unsigned char)UART0_RX_BUFFER_LEN, (unsigned      short)UART0_PKT_TIMEOUT);
     WriteUart0 = false;
if(Uart0TimeoutExpired)//errore timeout
AbortUart0Receive();
Uart0TimeoutExpired = false;
void SendUart0Data(unsigned char *pUart0Buffer, unsigned short NumData)
     *pDMA9_CONFIG &= (~DMAEN);
     *pDMA9_START_ADDR = pUart0Buffer;
     *pDMA9_X_COUNT = NumData;
     *pDMA9_X_MODIFY = 1;
     ssync();
     *pDMA9_CONFIG |= DMAEN;
     Uart0TxOk = false;
     ssync();
     *pUART0_IER |= ETBEI;
void ReceiveUart0Data(unsigned char *pUart0Buffer, unsigned short NumData, unsigned short Uart0Timeout)
     if(Uart0Timeout > 0)
          Uart0WaitingTime = (unsigned int)(Uart0Timeout * 1000) / ((unsigned int)(*pTPERIOD) / (Se2112Fcclk / 1000000));
          WaitForDataUart0 = true;
     *pDMA8_CONFIG &= (~DMAEN);
     *pDMA8_START_ADDR = pUart0Buffer;
     *pDMA8_X_COUNT = NumData;
     *pDMA8_CURR_X_COUNT = 0;
     *pDMA8_X_MODIFY = 1;
     ssync();
     *pDMA8_CONFIG |= DMAEN;
     *pUART0_IER |= ERBFI;
     Uart0RxOk = false;
void AbortUart0Receive(void)
     *pDMA8_CONFIG &= ~DMAEN;
     *pUART0_IER &= ~ERBFI;
     WaitForDataUart0 = false;
void CheckTimeoutUart0(void)
     if((WaitForDataUart0) && (!Uart0TimeoutExpired))
          if(Uart0WaitingCounter < Uart0WaitingTime)
               Uart0WaitingCounter++;
          else
               Uart0Errors++;
               Uart0TimeoutExpired = true;
               Uart0WaitingCounter = 1;
     else
UART0 ISR - IVG 10
EX_INTERRUPT_HANDLER(Uart0_ISR)
     unsigned short myDummyRead = 0;
     DMA8 (Uart0 Rx)
     if((*pSIC_ISR0 & DMA8_INT) != 0)
          //Interrupt Assertion
          *pDMA8_IRQ_STATUS |= DMA_DONE;
          myDummyRead = *pUART0_IIR;
          Uart0RxOk = true;
          Uart0Errors = 0;
     DMA9 (Uart0 Tx)
     if((*pSIC_ISR0 & DMA9_INT) != 0)
          *pDMA9_IRQ_STATUS |= DMA_DONE;
          *pUART0_IER &= ~ETBEI;
          *pDMA9_CONFIG &= ~DMAEN;
          while((*pUART0_LSR & TEMT) == 0);
          Uart0TxOk = true;
