BF518F16 internal flash booting
Question asked by AviMagos on Jan 12, 2015
Latest reply on Mar 10, 2015 by CommanderDave
I'm porting code/design from BF516F (which was discontinued) to BF518F16.
1) I've changed my project to BF518 instead of BF516, and rebuilt everything (I'm generating an .ldr composed of 2 project - an initcode and my main code)
2) I've used the new driver supplied as example in the site and was able to burn the flash successfully. I verified and compared the burned software.
However it seems that the booting from internal flash fails for some reason.
The BMODE bits are set correctly.
If I load my code via emulator directly to target memory, everything works fine.
Is there any idea why this is so?
BTW I'm using visual DSP update 9.0. - Where there any relevant changes since then? (chip errata etc.) Is there a new processor type that matches the BF518F16 (in the visual dsp there doesn't seem to be any difference between any of the BF518 when chossing target for project/emulation session).
Please help!!!
Thanks.
