ADUC 7061 - problem in interrupt handling
Question asked by Rajesh on Jan 7, 2015
Latest reply on Jan 7, 2015 by MMA
hi
          i'am using keil uvision 3 IDE ,in evaluation mode , i'am just trying a external interrupt 0 with a ADUC 7061 mnikit .
A key (push button) has connected to the External interrupt pin 0 ,
The code has written has follows..
if an interrupt has occured the  tempCount was incremented by one the uart prints the tempCount value after the // port0.2 pin push button was pressed.
when i'am pressing the interrupt key faster , the main while loop was not working.
sometimes after the hanging again pressed the interrupt key it became normal print in uart..
sometimes it also not even not working.
hardware description.
1. IRQ 0 was used as interrupt.
2. inputs were internal pullups were enabled
void IRQ_Handler(void) __irq
       unsigned long IRQSTATUS = 0;
       unsigned char ucCOMIID0 = 0;
       unsigned char ucComstatus = 0;
       IRQSTATUS = IRQSTA;   // Read off IRQSTA register
       if ((IRQSTATUS & BIT11) ) //UART interrupt source
            ucCOMIID0 = COMIID0;   // Read the UART IRQ ID register
       if ((ucCOMIID0 & 0x2) == 0x2)  // Transmit buffer empty
            ucTxBufferEmpty = 1;
       if ((ucCOMIID0 & 0x4) == 0x4)  // Receive buffer Full
            uartRxSt.rxBuffer[uartRxSt.count]=COMRX;
       if(uartRxSt.count < UART_BUF_LEN_MAX)
              uartRxSt.count++;
  if ((IRQSTATUS & BIT13) ) //External Interrupt0 source
  IRQCLRE = BIT13;   // Clear External Interrupt 0
  ExternalInterrutptStatus.Int0 =1;
  tempCount++;
  if ((IRQSTATUS & BIT18)) //External Interrupt2 source
  ExternalInterrutptStatus.Int2 =1;
  IRQCLRE = BIT18;   // Clear External Interrupt 2
main routine
void main()
externalInterruptConfigure();
while(1)
if(!(GP0DAT & 0x00000004 )) // port0.2 pin
  sprintf ( (char*)szTemp, "%d\r",tempCount );// Send the Received charachter to the UART
  printString((const unsigned char *)szTemp);
//printLenOfBytes((const unsigned char *)szTemp ,10);
Uart output for the interrupt counter...
Waiting for byte from PC<CR>
16<CR>
16<CR>
32<CR>
33<CR>
33<CR>
33<CR>
34<CR>
34<CR>
49<CR>
49<CR>
49<CR>
49<CR>
49<CR>
75<C>
75<CR>R>
75<CR>
75<CR>
75<CR>
75<CR
115<CR>
115<CR>
264<CR>
292<CR>
292<CR>
292<CR>
294<CR>
24600<CR>
24600<CR>
24600<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24611<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24651<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
24665<CR>
