ADV7181D YPrPb input support ?
Question asked by zbunix on Jan 6, 2015
Latest reply on Jan 9, 2015 by mattp
Our use case is as follows:
Input:
    525p/60Hz YPrPb
Output:
  YCbCr  8Bit 422 HS/VS
  VS pin and DE pin are used. (SAV/EAV is not used.)
script configure:
##CP 525p/625p##
:525p/60Hz YPrPb In 8Bit 422 HS/VS Encoder:
42 05 01 ; PRIM_MODE = 001b COMP
42 06 06 ; VID_STD for 525P 2x1
42 C3 56 ; ADC1 to Ain8, ADC0 to Ain10,
42 C4 B4 ; Enables manual override of mux & ADC2 to Ain6.
42 1D 47 ; Enable 28.63636MHz crystal
42 3A 11 ; Set Latch Clock 01b. Power down ADC3.
42 3B 81 ; Enable Internal Bias
42 3C 3B ; PLL QPUMP to 011b
42 6B 83 ; 422 8bit out
42 C9 00 ; SDR mode
42 73 CF ; Enable Manual Gain and set CH_A gain
42 74 A3 ; Set CH_A and CH_B Gain - 0FAh
42 75 E8 ; Set CH_B and CH_C Gain
42 76 FA ; Set CH_C Gain
42 7B 1C ; Turn off EAV and SAV Codes. Set BLANK_RGB_SEL.
42 85 19 ; Turn off SSPD and force SOY
42 86 0B ; Enable STDI Line Count Mode
42 BF 06 ; Blue Screen Free Run Colour
42 C0 40 ; default color
42 C1 F0 ; default color
42 C2 80 ; Default color
42 C5 01 ;
42 C9 08 ; Enable 8-bit mode using psuedo DDR
42 0E 80 ; ADI recommended sequence
42 52 46 ; ADI recommended sequence
42 54 80 ; ADI Recommended Setting
42 57 01 ; ADI recommended sequence
42 F6 3B ; ADI Recommended Setting
42 0E 00 ; ADI recommended sequence
42 67 2F ; DPP Filters
End
our sch file
Question 1
520P YPbPr input no work OK( no video image disaplay) blue screen bug, help us check?
Question 2
Y ---- ADC0   Pb --- ADC1  Pr --- ADC2  right? configure other (e.g. Y--ADC3 Pb--ADC2) ?
Question 3
1) remove horizontal blank, only have active data(720x2=1440), similar CMOS sensor output(HREF pin) timing ?  from  pin  DE mode
2) remove vertical blank line, only have active line (480 line), similar CMOS sensor output(VSYNC pin) timing ?     from pin VS
our post need timing :
