AD5292 Not Changing Resistance/Wiper Resistance Staying at 50kohms
Question asked by SIM_novice on Dec 31, 2014
Latest reply on Jan 5, 2015 by harryh
Just like other people I am having trouble changing the wiper resistance. I have read through the other posted discussions related to the same issues I have but did not seem to resolve my problem. I have connected the circuit the same as other people's, VDD,VSS,Vlogic, and GND(both analog and digital) the correct way that the datasheet describes and the SPI signals looked exactly the same on the LogicPort Analyzer as on the datasheet. After sending hex1803 and hex0500 commands, the wiper resistance was still sitting at 50kohms and nothing ever seems to work.
So as of right now, I am just trying to hook up a very simple circuit to test the wiper resistance. Here are my connections:
VDD--- +15V
VSS--- -15V
Vlogic--- floating
Reset--- floating
EXT_Cap--- floating
SCLK -- SCLK (start from low, sample output on falling edge)
DIN--- MOSI
SYNC--- low on IDLE
SDO --- floating
RDY--- floating
Terminal A--- floating
Terminal W--- Multimeter
Terminal B---GND
Very simple circuit with only power supply voltages and SPI signals connected. Both the digital and analog GND are shorted together. Terminal A is floating while Terminal W and B are connected to the multimeter to check if the wiper resistance is changing when sending commands. My question is: would this circuit work like this with the other connections floating and simply to test out the wiper resistance? Please let me know if you need any further information from me. Thanks in advance!
Best Regards,
Bruce
