PIXC and EPPI 's RGBFMTEN can be used together ?
Question asked by qian on Dec 21, 2014
Latest reply on Dec 22, 2014 by qian
Board with a RGB666 LCD screen.
When not in use PIXC, images can be displayed properly .
Such a data stream is:MEM(RGB888)->DMA->EPPI-->LCD(RGB666)
EPPI and DMA configuration is as follows :
//These parameters from the data sheet of the LCD screen .
/* Active pixels per line */
#define LCD_ACTIVE_PIXELS_PER_LINE       640//480u
/* Active lines per frame */
#define LCD_ACTIVE_LINES_PER_FRAME       480//272u
/* Number of Horizontal front porch clocks */
#define LCD_HFRONT_PORCH                 16//2u
/* Number of Horizontal back porch clocks */
#define LCD_HBACK_PORCH                  48//2u
/* Horizontal pulse width */
#define LCD_HPULSE_WIDTH                 96//41u
/* Number of vertical front porch (in terms of lines) */
#define LCD_VFRONT_PORCH                 10u//2u
/* Number of back porch (in terms of lines) */
#define LCD_VBACK_PORCH                  33u//2u
/* Vertical pulse width (in terms of lines) */
#define LCD_VPULSE_WIDTH                 2u//10u
#define LCD_HPERIOD                   800//525u
#define LCD_VPERIOD                 525u//286u
#define  LCD_PIXELS_WIDTH    LCD_ACTIVE_PIXELS_PER_LINE
#define  LCD_PIXELS_HEIGHT   LCD_ACTIVE_LINES_PER_FRAME
#define  LCD_PIXELS_DEPTH     3   //Color depth  (RGB888)
#define  LCD_PIXELS_SIZE  (LCD_PIXELS_WIDTH*LCD_PIXELS_HEIGHT*LCD_PIXELS_DEPTH)
void InitEPPI1(void)
  *pREG_EPPI1_CTL = ENUM_EPPI_CTL_TXMODE |
   ENUM_EPPI_CTL_NON656 |
   ENUM_EPPI_CTL_SYNC2 |
   ENUM_EPPI_CTL_INTCLK |
   ENUM_EPPI_CTL_INTFS |
   ENUM_EPPI_CTL_PACK_EN |
   ENUM_EPPI_CTL_POLC00 |
   ENUM_EPPI_CTL_FS1LO_FS2LO |
   ENUM_EPPI_CTL_RGBFMT_EN |
   ENUM_EPPI_CTL_ZEROFILL |
   ENUM_EPPI_CTL_DLEN18;  //RGB666
  *pREG_EPPI1_CLKDIV = 0X3;
  *pREG_EPPI1_LINE  = LCD_HPERIOD;
  *pREG_EPPI1_FRAME = LCD_VPERIOD;
  *pREG_EPPI1_HCNT = LCD_ACTIVE_PIXELS_PER_LINE;
  *pREG_EPPI1_VCNT = LCD_ACTIVE_LINES_PER_FRAME;
  *pREG_EPPI1_FS1_WLHB  = LCD_HPULSE_WIDTH;
  *pREG_EPPI1_FS1_PASPL = LCD_HPERIOD;
  *pREG_EPPI1_FS2_WLVB  = LCD_HPERIOD  * LCD_VPULSE_WIDTH;
  *pREG_EPPI1_FS2_PALPF = LCD_HPERIOD  * LCD_VPERIOD;
  *pREG_EPPI1_HDLY = LCD_HPULSE_WIDTH + LCD_HBACK_PORCH-1;
  *pREG_EPPI1_VDLY = LCD_VPULSE_WIDTH + LCD_VBACK_PORCH;
void InitDMA(void)
  *pREG_DMA33_ADDRSTART = gpLcdDisplayBuf;
  *pREG_DMA33_XCNT = LCD_PIXELS_WIDTH*LCD_PIXELS_DEPTH/4;
  *pREG_DMA33_XMOD = 4;
  *pREG_DMA33_YCNT = LCD_PIXELS_HEIGHT;
  *pREG_DMA33_YMOD = 4;
  *pREG_DMA33_CFG = ENUM_DMA_CFG_MSIZE04 |
   ENUM_DMA_CFG_PSIZE04 |
   ENUM_DMA_CFG_ADDR2D |
           ENUM_DMA_CFG_SYNC |
           ENUM_DMA_CFG_STOP|
           ENUM_DMA_CFG_YCNT_INT;
           //ENUM_DMA_CFG_AUTO;
Original image :
But when the EPPI sent via VID connected to PIXC, LCD screen image is 9 points .
Data flow is this: MEM(UYVY422)-->DMA-->PIXC(UYVY->RGB888)-->EPPI-->LCD(RGB666)
The image is scaled and displayed nine .
void osd_Vss_cfg(void)
  *pREG_VID0_CONN = 0x00001000; //PIXC_TX->EPPI1_TX
  ssync();
void InitPixc(void)
//UYVY to RGB888  OVERLAY is RGB
  *pREG_PIXC0_CONRY  = 0x4002CC80;
  *pREG_PIXC0_CONGU  = 0x7D4E9480;
  *pREG_PIXC0_CONBV  = 0x4E200080;
  *pREG_PIXC0_CCBIAS = 0x31E21F4D;
  *pREG_PIXC0_PPL = VIDEO_IN_WIDTH;
  *pREG_PIXC0_LPF = VIDEO_IN_HEIGHT;
  *pREG_PIXC0_CTL = (uint32_t)(
          //BITM_PIXC_CTL_OVENA  |
  BITM_PIXC_CTL_OVFRMT |         //RGB
  BITM_PIXC_CTL_ENTC
  );         //半透明
  ssync();
  *pREG_PIXC0_HSTART_A = 0u;
  *pREG_PIXC0_HEND_A = (uint16_t)OVERLAY_WIDTH;
  ssync();
  *pREG_PIXC0_VSTART_A = 0;
  *pREG_PIXC0_VEND_A = (uint16_t)OVERLAY_HEIGHT;
  ssync();
  *pREG_PIXC0_TRANSP_A = 15;//TranspRatio;
  ssync();
  *pREG_PIXC0_TC = 0x070707;//0x00000000;//0x070707;
  ssync();
//pixc input
void InitDMA35(void)
  *pREG_DMA35_ADDRSTART = goVideoInBuf[1];
  ssync();
  *pREG_DMA35_XCNT = LCD_PIXELS_WIDTH*2/4;
  *pREG_DMA35_XMOD = 4;
  *pREG_DMA35_YCNT = LCD_PIXELS_HEIGHT;
  *pREG_DMA35_YMOD = (720-640)*2+4;  //window  720x576  ->  640*480
  *pREG_DMA35_CFG  = (uint32_t)(ENUM_DMA_CFG_ADDR2D |
  ENUM_DMA_CFG_STOP |
  ENUM_DMA_CFG_SYNC |
  ENUM_DMA_CFG_READ);
  ssync();
