AD9102: help with /TRIGGER programming
Question asked by tkutscha on Dec 18, 2014
Latest reply on Jan 16, 2015 by larrywelchusa
Hi All,
I'm having difficulty setting up the AD9102 to output a burst of DAC values from the SRAM every time the /TRIGGER signal goes low.
The basic operating conditions are the following:
  • CLKP/CLKN input is running continuously at 50MHz
  • /TRIGGER signal has a falling edge every 10us (100KHz frequency, low about 5% of the time)
My goal is to have 8 values from the SRAM (addresses 0x6000-0x6007) that "burst" out of the AD9102 every time the /TRIGGER signal goes low.
Here is my C code to do so:
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00002004); /* SPICONFIG - reset */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00000000); /* SPICONFIG */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x000101C7); /* POWERCONFIG */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00020000); /* CLOCKCONFIG */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00030000); /* REFADJ */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00070000); /* DACAGAIN */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00080000); /* DACRANGE */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x000C000A); /* DACRSET */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x001E0000); /* PAT_STATUS - STOP */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x001D0001); /* RAMUPDATE */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x001F0001); /* PAT_TYPE - finite */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00200000); /* PATTERN_DLY */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00258000); /* DACDOF - max negative */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00270000); /* WAV_CONFIG - SRAM values */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00280111); /* PAT_TIMEBASE */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x0029000A); /* PAT_PERIOD */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x002B0001); /* DAC_PAT - 1 time */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x002C0001); /* DOUT_START */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x002D0010); /* DOUT_CONFIG */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00318000); /* DAC_CST */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00354000); /* DAC_DGAIN 0x400=1x */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00370007); /* SAW_CONFIG */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x003E0100); /* DDS_TW32 */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x003F0000); /* DDS_TW1 */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00430000); /* DDS_PW */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00440002); /* TRIG_TW_SEL */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00450003); /* DDS_CONFIG */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x00470000); /* TW_RAM_CONFIG */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x005C0000); /* START_DELAY */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x005D0000); /* START_ADDR (<<4) */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x005E0070); /* STOP_ADDR (<<4) */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x005F0001); /* DDS_CYC */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x001E0004); /* PAT_STATUS - MEM_ACCESS ON */
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60001000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60010000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60022000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60030000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60043000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60050000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60064000);
SPIbusSet(SPIBUS_DEV_AOM_DAC,0x60070000);
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x001E0000); /* PAT_STATUS - MEM_ACCESS OFF */
SPIbusSet(SPIBUS_DEV_AOM_DAC, 0x001E0001); /* PAT_STATUS - RUN */
If I run this code, I get the following on the oscilloscope:  (blue is DAC output, yellow is /TRIGGER signal)
Great!  this is what I was looking for, except for a significant delay from the falling edge of /TRIGGER to the output.
Now, if I zoom out, I get the following:
Wait a minute! I get only one "burst" of DAC output.  Additional falling edges on /TRIGGER don't cause additional output bursts.
If I zoom out even further, I get the following:
It looks like I get more bursts of DAC output, but only every 65536 CLKP/CLKN edges.  Seems we have a 16-bit free-running counter in the ad9102 that isn't getting reset/zeroed-out by the /TRIGGER signal.
Two questions:
  1. How do I change the register settings to generate a burst of DAC outputs from the SRAM every time the /TRIGGER signal goes low?
  2. How do I minimize the delay between the falling edge on the /TRIGGER signal to the first output DAC value?
I find the documentation very confusing, so thanks for any input you might have on this.
Thanks!
Tim
