Sharc 21489 ping pong dma synchronization
Question asked by QuentinBerthet on Dec 17, 2014
Latest reply on Jun 4, 2015 by Harshit.Gaharwar
I have issue in a project on a custom board with ADSP21489:
I try to adapt a talkthru C example to my board (Chained DMA with ping pong buffer). The problem is that I get some periodic corrupted sample on the output. The interesting point is that if I stop the debug session (terminate and remove), then the system run correctly without corruption.
I suspect that this have something to do with my output DMA being de-synchronized with the input DMA and copying output buffer while it is written by the (very basic) process loop, but I can't figure how to ensure synchronization and why the system run correctly after disconnecting is a mystery for me.
The main modification from the talkthru example are:
- SPORT0 used as a slave I2S input driven by the I2S incoming clocks (96khz)
- SPORT3 used as a slave I2S output driven by the PCG
- PCG used to generate I2S word clock (96khz) and bit clock from an external 24.576mhz master clock
I am using CrossCore Studio version 1.0.3.0 and ADZS-USB-ICE as emulator.
I join an example that reproduce the issue on my hardware, maybe someone can spot the mistake.
Any help greatly appreciated !
