AD8556 failed output waveform
Question asked by ricky on Dec 16, 2014
Hi All,
My customer has trouble with his board in which he utilizes AD8556 In-Amp.
Load Cell is connected to the input of AD8556 and the output of AD8556 is connected to MCU.
He first found noisy waveform from AD8556 in his board.
Then I suggest that disconnect the load cell and apply DC voltage to the input of AD8556.
Also I suggested disconnecting output from MCU, and disconnecting line from MCU to DIGIN terminal in order for isolating customer’s circuit.
The attached file shows scope shot for the AD8556 input/output/power supplies terminals.
As shown attached scope shot, large spike noise appeared on output and filt/gigout terminal.
He needs to find the cause of the problem in his circuit and fix this failure as soon as possible.
Could you suggest us what would be a cause of failure for AD8556 device?
Best Regards,
Ricky
