Statistical Profiling Automation ezKit TS201
Question asked by lucas_embraer on Dec 12, 2014
Latest reply on Dec 18, 2014 by lucas_embraer
I`m trying to automate the process of statistical profiling in the TS201 of a ezkit. With simulation or connecting with the ezkit by USB or ICE and using the Visual DSP IDE I can extract the profile and save it. But when I use the automation API the profile collected is always empty.
Here is the code I'm using:
   pSession = pApp->CreateMPSession( buffer, session_info->debug_target, session_info->plataform_name)
    pProcessor = pSession->ProcessorList->GetItem( CComVariant( 1 ) );
    pMemoryType = pProcessor->MemoryTypeList->GetItem( (long)0 );
    IADspProfileSessionListPtr pProfileSessionList = pProcessor->ProfileSessionList;
    pProfileSession = pProfileSessionList->CreateSession("TigerSharc Memory 1");
    pProfileSession->MemoryName = pProfileSessionList->MemoryNames->Item(0);
    pProfileSession->Metrics = pProfileSessionList->GetAvailableMetrics(pProfileSession->MemoryName);
    pProfileSession->FilterType = profileEntireMemory;
    pProfileSession->DebugSamplesOnly = FALSE;
    pProcessor->LoadProgram("C:\\Test.dxe");
    pProcessor->Run(TRUE);
    printf("Elapsed Total: %d\n", pProfileSession->TotalSampleCount);
    pProfileSession->SaveProfileData("C:\\myprofile3", profileXML);
I already checked and the profile is marked as enabled. The Total Sample time is also zero.
The resulted profile is:
<?xml version="1.0" encoding='ISO-8859-1'?>
<visualdsp-profile-session schema="1">
  <session-summary>
  <profile-session-name>"TigerSharc Memory 1"</profile-session-name>
  <profile-id>0</profile-id>
  <memory-id>0</memory-id>
  <ignore-no-debug-info-sample>0</ignore-no-debug-info-sample>
  <enabled>1</enabled>
  <filter-type>0</filter-type>
  <total-sample-count>0</total-sample-count>
  </session-summary>
  <execution-unit-list>
  </execution-unit-list>
</visualdsp-profile-session>
Another problem that I found is that the profile is being saved at the "AppData\Local\VirtualStore" folder of the current user. Is there a way to change it?
