adv7604 custom res 1280 x 960
Question asked by mhb27 on Dec 11, 2014
Latest reply on Dec 15, 2014 by mhb27
i followed through on the auto graphics process for non supported graphics but it seems to still not be getting a lock no matter what i change.
DVI input format:
Hactive:     1280
Vactive:     960
I/P:          progressive
Htotal:     1800
Hblank:     520
Hfront:     98
Hsync:     114
Hback:     308
Hpol:          low
Vtotal:     981
Vblank:     21
Vfront:     1
Vsync:     3
Vback:     17
Vpol:          low
HFreq:     58.1KHz
VFreq:     59.2Hz
Pclock:     104.6MHz
code:
//  Program the primary mode to graphics: PRIM_MODE[5:0] = 0b0010
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_PRIM_MODE, 0b00000010 );
  //  Program the video standard to auto graphics: VID_STD[3:0] = 0b00111
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_VID_STD, 0b00000111 );
  //  Generate the pixel clock for 1280 x 960 resolution
  //  Firstly, PLL_DIV_MAN_EN is set to 1 to enable manual programming of the PLL block.
  //  Secondly, one of the two following methods is used to calculate the value of PLL_DIV_RATIO[12:0] to give the required pixel clock.
  //  Method one or method two is chosen, depending on the information available about the non standard format.
  u_int32_t pc =  104600000;
  u_int32_t hsync = 58100;
  u_int32_t pClock = pc/hsync;
  u_int8_t first = (pClock>>8)| 0xC0;
  u_int8_t last = pClock;
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_16, first );
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_17, last );
  //  Configuring the Free Run Mode Line Length
  //  The expected line length for non standard formats must be programmed to the CP core. FR_LL[10:0] (free run line length) is the number
  //  of system clock cycles in the ideal line length of the video format.
  uint8_t baseReg;
  u_int32_t sysClock = 28636300;
  u_int32_t freemode = sysClock/hsync;
  first = freemode>>8;
  last = freemode;
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8F, first );
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_90, last );
  status = adv7604_read( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_46_2, &baseReg );
  baseReg |=  (first& 0b111);
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_46_2, baseReg );
     status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_48, last );
  //  Setting the Free Run Mode Number of Lines per Field
  //  The expected number of lines per field for non standard formats must be programmed to the CP core.
     u_int16_t vTotal = 981;
     u_int16_t numLines = vTotal<<4;
     first = numLines>>8;
     last = numLines;
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_AB_1, first );
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_AB_2, last );
  //  Configuring the Interlaced or Progressive Parameter
  //  Progressive Mode
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_91, 0x50 );
  // Adjust the horizontal and vertical position, height, and width by varying the values of DE_H_START[9:0] and DE_H_END[9:0].
  // Also need to adjust the values in DE_V_START[9:0] and DE_V_END[9:0]
  // s sign  e sign
  // DE_H_START
  // DE_H_END
  uint16_t de_h_start = 308;
  uint16_t de_h_end = -98;
  status = adv7604_read(this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8B, &baseReg );
  baseReg &= 0xF0;
  baseReg += (0x03&(de_h_start>>8))<<2;
  baseReg += (0x03&(de_h_end>>8));
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8B, baseReg);
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8C, (de_h_end & 0xff) );
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8D, (de_h_start & 0xff) );
  // DE_V_START split DE_V_END
  uint8_t de_v_start = 17;
  uint8_t de_v_end = -1;
  baseReg = de_v_start<<4;
  baseReg += (de_v_end & 0x0F);
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8E, baseReg );
  // CP_START_VBI
  // split
  // CP_END_VBI (no interlacing)
  uint16_t cp_start_vbi = 981-1+1;
  uint16_t cp_end_vbi = 3+17+1;
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A5_1, (cp_start_vbi>>4) );
  baseReg = (cp_start_vbi<<4)& 0xF0;
  baseReg+= ((cp_end_vbi>>8)& 0x0F);
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A5_2, baseReg );
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A7, (cp_end_vbi&0xFF) );
  // CP_START_VBI_EVEN
  // split
  // CP_END_VBI_EVEN (interlacing)
  uint16_t cp_start_vbi_even = 981-0+1;
  uint16_t cp_end_vbi_even = 981+3+18+1;
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A8_1, (cp_start_vbi_even>>4) );
  baseReg = (cp_start_vbi_even<<4)& 0xF0;
  baseReg+= ((cp_end_vbi_even>>8)& 0x0F);
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A8_2, baseReg );
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_AA, (cp_end_vbi_even&0xFF) );
  //  Adjusting the Vertical or Horizontal Alignment
  //  Adjust the EAV and SAV code position by varying the values in CP_START_EAV[11:0] and CP_START_SAV[11:0]
  // CP_START_SAV
  // split
  // CP_START_EAV
  uint16_t cp_start_sav = 114+308-4;
  uint16_t cp_start_eav = 1800-98;
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A2_1, (cp_start_sav>>4) );
  baseReg = (cp_start_sav<<4)& 0xF0;
  baseReg+= ((cp_start_eav>>8)& 0x0F);
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A2_2, 0xa6 );
  status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A4, (cp_start_eav &0xFF) );
