CAN Module: Extended ID?
Question asked by gpetrowitsch on Oct 26, 2010
Latest reply on Nov 9, 2010 by jobo23
I'm a bit confused with respect to the Extended ID register fields
in the Blackfin CAN module (BF548).
The documentation lists 3 fields in figure 27-3 - the BASEID, the
EXTID_LO and the EXTID_HI. But when I look at the register
description EXTID_LO are bits [17..16] of the extended ID while
EXTID_HI are bits [15..0].
Shouldn't the field with the higher bit numbers be called _HI ?
Or does this imply any kind of reverse bit ordering ???
If you don't understand, what I'm talking about, perhaps you can
answer this question:
If I have a 29 bit extended CAN ID - let's name it ID[28..0] - is it
then correct to do this assignment (for a transmit mailbox)
BASEID = ID[10..0]
EXTID_HI = ID[26..11]
EXTID_LO = ID[28..27]
Thanks and regards,
Gerhard
