libiio segmentation fault on write
Question asked by Daniel_Camara on Dec 5, 2014
Latest reply on Jan 9, 2015 by pcercuei
Hi everyone,
  I am trying to use a FMCOMMS4 card with and a zedboard and trying to run the examples that come with the analog device gnu-radio distribution but I am having a segmentation fault on "iio_channel_attr_write_raw () from /usr/lib/libiio.so.0", as I manage to get passing gdb over the core dump (gdb python core).  The core is also strange, it complains about possible corrupted stack (see below).
  I have seen this discussion (ZedBoard & fmcomms2 : running iiostream example) the problem is close, but I manage to run the ad9361-iiostream without a problem,  I try updating the image as advised, but no use. The interesting thing, the different is that the problem occurs only when I try to call the examples of gnu-radio. For example, if I try to call one of the examples on gnuradio/iio-examples (the top_block.py gennerated by cyclic-sine.grc) I get a core.
> gdb python core
(gdb) bt
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `python ./top_block.py'.
Program terminated with signal 11, Segmentation fault.
#0  0xb42bc412 in iio_channel_attr_write_raw () from /usr/lib/libiio.so.0
(gdb) bt
#1  0xb42bca70 in iio_channel_attr_write_double () from /usr/lib/libiio.so.0
#2  0xb42d3f28 in gr::iio::fmcomms2_source_impl::set_params(unsigned long long, unsigned long, unsigned long, bool, bool, bool, char const*, double, char const*, double, char const*) () from /usr/lib/libgnuradio-iio-3.7.4git.so.0.0.0
#3  0xb42e0780 in vtable for gr::iio::fmcomms2_source_impl ()
#4  0xb42e0780 in vtable for gr::iio::fmcomms2_source_impl ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
   Any ideas?!?!?
            Best regards...
               Daniel
