AD7176 ReadRegister CRC code
Question asked by Tom_Spargo on Dec 2, 2014
Latest reply on Dec 11, 2014 by jcolao
I have the ADI C code for the AD7176-2 (see below). When CRC is enabled, shouldn't there be a CRC calculation for the write command to the Communications Register that occurs before the read operation? The CRC result should be added to 'buffer' and then SPI_Read would be called...?
Tom
int32_t AD7176_ReadRegister(st_reg* pReg)
    int32_t ret       = 0;
    uint8_t buffer[8] = {0, 0, 0, 0, 0, 0, 0, 0};
    uint8_t i         = 0;
    uint8_t check8    = 0;
  uint8_t msgBuf[8] = {0, 0, 0, 0, 0, 0, 0, 0};
    /* Build the Command word */
    buffer[0] = COMM_REG_WEN | COMM_REG_RD | pReg->addr;
    /* Read data from the device */
    ret = SPI_Read(AD7176_SLAVE_ID,
                   buffer,
                   ((AD7176_st.useCRC != disable) ? pReg->size + 1
                                                  : pReg->size) + 1);
    if(ret < 0)
        return ret;
    /* Check the CRC */
    if(AD7176_st.useCRC == use_CRC)
    msgBuf[0] = COMM_REG_WEN | COMM_REG_RD | pReg->addr;
    for(i = 1; i < pReg->size + 2; ++i)
    msgBuf[i] = buffer[i];
    <Shouldn't there be a CRC calculation here?>
    check8 = AD7176_ComputeCRC8(msgBuf, pReg->size + 2);
    if(AD7176_st.useCRC == use_XOR)
        check8 = AD7176_ComputeXOR8(msgBuf, pReg->size + 2);
<snipped>
