ADV7611 Output Clock Instability and Overheating w DVI or HDMI Source Input
Question asked by danngai on Dec 1, 2014
Latest reply on Dec 5, 2014 by GuenterL
Thank you in advance for your help on this.  I am using the ADV7611 device for HDMI Reception and have encountered some problem.  I am including the setup conditions and problems.  I am also attaching the scripts used [from Engineer Zone] that were used to setup the registers of the ADV7611.   Thank you!
Dan
Background/Conditions
  • Copied design directly from Dev Board [copy of schematic will be sent upon request]
  • ADV7611 connected straight into FPGA
  • Successful communication to ADV7611 via I2C
  • Can bring ADV7611 out of reset via I2C
  • Read/Write to any of the MANY MANY registers in ADV7611
  • Copied and used most recent PUBLISHED SCRIPTS for setting registers [directly from Engineering Zone]
  • Without HDMI or DVI input, has successfully set up ADV7611 to free run and and output Pixel, HS, VS clocks are correct and within specification
  • Can set up via I2C any of the various resolutions and frame rates with accurate Pixel, HS, VS clocks on the output of the ADV7611
HDMI Source Input
  • Using Published Scripts for setting registers [see attachment]
  • ADV7611 set to 720p60
  • ADV7611 set to Free Run
  • HDMI Hot or Cold Plugin
HDMI SOURCE PROBLEM:
  • Pixel Clock, HS and VS Clocks unstable and don’t lock to correct frequency value
  • ADV7611 heats up within 1-2 Seconds and must be SHUT DOWN to avoid damage
DVI Source Input
  • HDMI Reset set to Ignore [No Hot Plug Detect]
DVI SOURCE PROBLEM:
  • Can see TMDS Clock
  • HOWEVER, Pixel Clock, HS and VS Clocks unstable and don’t lock to correct frequency value
  • ADV7611 heats up and eventually must be shut down to avoid overheating
