forcing ADC_SDATA to act as a PWM
Question asked by dimitris. on Nov 30, 2014
Latest reply on Dec 9, 2014 by JohnTo
Hi forum,
I am trying to force the I2S digital output (pin 26 on an ADAU1761) to output a PWM signal.
In order to succeed this I am forcing the I2S output to certain DC values by using DC sources in SigmaStudio.
Ideally, I would like to enable the first bit of the I2S output and then one by one add the rest of the 23 I2S bits.
However, I am a bit confused on how the I2S values map to DC voltages.
I have figured out that a -1 DC voltage value will force the DIG0 to enable the MSB of the I2S output.
Then in order to keep  activating the rest of the I2S bits in a sequence I am using the values in the following table:
DC voltage value (5.23 format)I2S bit
below -1first MSB enabled
-1                   (-1/2^0)first MSB enabled
-0.5                (-1/2^1)first 2 MSB enabled
-0.25              (-1/2^2)first 3 MSB enabled
-0.125            (-1/2^3)first 4 MSB enabled
-0.0625          (-1/2^4)first 5 MSB enabled
-0.03125         (-1/2^5)first 6 MSB enabled
-0.015625        (-1/2^6)first 7 MSB enabled
?first 8 MSB enabled
?first 9 MSB enabled
?first 10 MSB enabled
however I cannot seem to activate more than 7 MSBs in a row. The DC voltage cannot output a value as low as necessary in order to activate the rest of the bits.
Any idea how I could activate the rest of the I2S bits?
How convention does SigmaStudio use in order to map the I2S data to DC values?
thanks
