Understand ADXL345 output
Question asked by memphile on Nov 27, 2014
Latest reply on Dec 1, 2014 by Achim
Hi Folks,
I am newbie in MEMS domain. In order to learn MEMS motion sensors (for few undecided projects) I borrowed an RL78/ADXL345 board from friend and started playing with it. I am attempting to derive simple velocity/distance in X direction via integration.
1. I have put the board on horizontal table. At this time I expect ax to be zero, after being compensated for 0g. I see that ADXL345, does give zero values for ax, when I push the board in x direction gently, I see non-zero accel in x dir. However, after 25 sec or so, the velocity seems to drift. Could someone help me understand this, please ? I do expect velocity to become inaccurate, due to integration, but not as early as 25 sec. My code is given below.
2. Init - ADXL345 like this -
   /* accelerometer data format                     */
   /* range +/- 16g                                        */
   /* right justified with sign extension           */
   /* Full resolution mode                              */
    WriteIIC(ADXL345_ADDR, DATA_FORMAT_REG, 0x3);
   /* put FIFO into FIFO mode                     */
    WriteIIC(ADXL345_ADDR, FIFO_CTRL, 0x40);
    /* set x offset register                         */
    /* this value is determined by just turning on adxl345, and observing x-axis accel from DATAX0 */
    WriteIIC(ADXL345_ADDR, OFSX, 0xFF);
     /* set Sample rate              400 Hz       */
    WriteIIC(ADXL345_ADDR, BW_RATE, 0x0c);
   /* take accelerometer out of standby mode        */
    WriteIIC(ADXL345_ADDR, POWER_CTRL, 0x08);
3. Here is how I determine velocity/distance. I am averaging acceleration in X dir with previous sample.
  while (1U)
    if ((fifo_lvl = ADXL345_GetFifoLevel()) > 0)
      sprintf(buff, "Fifo Lvl: %d      ", fifo_lvl);
      DisplayLCD(LCD_LINE3, (uint8_t *) buff);
      ADXL345_ReadFifo(fifo_data);
      /* scale factor for +/- 16g range */
      ax = ((float)((fifo_data[1] << 8) | fifo_data[0])*31.0/1000.0);
      sprintf(buff, "X axis: %f      ", ax);
      DisplayLCD(LCD_LINE4, (uint8_t *) buff);
       /* velocity by inregration */
      /* value of delay = 1/ sample freq = 2.5 ms /*
      new_velocityx = old_velocityx + (((ax+old_ax)*(float)delay)/2.0)/1000.0;
      sprintf(buff, "velx: %f      ", new_velocityx);
      DisplayLCD(LCD_LINE5, (uint8_t *) buff);
      old_velocityx = new_velocityx;
      old_ax = ax;
