How to minimize lock time of ADF4153
Question asked by kt315 on Nov 24, 2014
Latest reply on Dec 8, 2014 by Brigid.Duggan
Dear friends
I need to obtain the lock time of PLL ADF4153 strictly less than 1 ms. The reference frequency is 12.8 MHz, PFD frequency is 6.4 MHz, loop bandwidth is 7.5 kHz. RFout = 320 MHz (this is slightly less than minimum RFout from datasheet). In attachement - my project from ADIsimPLL.
Unfortunately I cannot stabilize the PLL lock time. It appears to be random (from 600 ms to 2000 ms) after writing registers.
Here is the sequence I write into registers (from datasheet, page 18 "INITIALIZATION SEQUENCE"):
000003
0003C7
0003C6
108401
0C8004
0003C2
Figure 1 - Waveforms from oscilloscope (two different curves resulting from the same initialization sequences with the same external conditions. It is seen that the lock time strongly varies)
Probably the internal state of ADF4153 may cause lock time to randomize when LE goes high after procedure of writing registers.
Wouldn't you advise me what should I do to stabilize and minimize the lock time as much as possible?
Thanks in advance
