Problems with FMCOMMS2+Simulink+Libiio
Question asked by Arne_2 on Nov 21, 2014
Latest reply on Nov 27, 2017 by ACozma
Hello there
I am having some problems running the Simulink example (ad9361_sim.slx ) found on Simulink libiio    [Analog Devices Wiki]
I am using the Zedboard and the FMCOMMS2 (ad9361)
I followed the Zynq Quick Start Guide [Analog Devices Wiki] to setup the Zedboard.
I installed the libiio x64 for windows, and on my Zedboard the 2014_R1 branch of the libiio library by following the instructions.
I installed Windows SDK and made sure it is working using mex -setup:
MEX configured to use 'Microsoft Windows SDK 7.1 (C)' for C language compilation.
Warning: The MATLAB C and Fortran API has changed to support MATLAB
  variables with more than 2^32-1 elements. In the near future
  you will be required to update your code to utilize the
  new API. You can find more information about this at:
  http://www.mathworks.com/help/matlab/matlab_external/upgrading-mex-files-to-use-64-bit-api.html.
I set the function block parameters of the ad9361 block to the IP address of my Zedboard (192.168.11.209).
When I ran the model, I received a window with the error message:
"The Simulink system object is outdated! Download the latest version from the Analog Devices github repository."
This error message was generated from line 107 in libiio_if.m
I double checked and re-installed the libiiosetup_x64.zip
I confirmed that I have version 1.0.4 on the PC, which was the latest available (from today).
When I debug the origin of the error message from libiio_if.m, I can probe the versions that libiio_if.m has been detecting:
libiio_if: Remote libiio version is 0.2, d994f7c
libiio_if: libiio dll version is 0.1, git
I guess I need some help here....
Arne
