Questions Regarding ADE7880 Harmonics Calculations
Question asked by karens on Nov 18, 2014
Latest reply on Nov 24, 2014 by dlath
Hello
Using ADE7880 to do the harmonics calculations, here are THD values on the voltage and current:
Phase A: THD on voltage is 0.8496; THD on current is 0.8488
Phase B: THD on voltage is 0.8363; THD on current is 0.849
Phase C: THD on voltage is 0.8401; THD on current is 0.8529
The load is resistance load, line voltage frequency is 60Hz (actually measured frequency is 61Hz, don't know why?). I am not sure if these are reasonable values or not. Upon the equations shown on data sheet page 59, I was expected that the THD values should be much smaller. Based on your experience, how could I estimate those THD values? I want to make sure the harmonics calculation I did are correct.
I use the default settings of HX, HY, and HZ.
Phase A: Harmonic X distortion on voltage is 0.000764
               Harmonic Y distortion on voltage is 0.001344
               Harmonic Z distortion on voltage is 0.000052
               Harmonic X distortion on current is 0.321839
               Harmonic Y distortion on current is 0.001433
               Harmonic Z distortion on current is 0.000050
Phase B: Harmonic X distortion on voltage is 0.000188
               Harmonic Y distortion on voltage is 0.001620
               Harmonic Z distortion on voltage is 0.000024
               Harmonic X distortion on current is 0.000585
               Harmonic Y distortion on current is 0.001660
               Harmonic Z distortion on current is 0.000016
Phase C: Harmonic X distortion on voltage is 0.001041
               Harmonic Y distortion on voltage is 0.001591
               Harmonic Z distortion on voltage is 0.000020
               Harmonic X distortion on current is 0.000543
               Harmonic Y distortion on current is 0.001588
               Harmonic Z distortion on current is 0.000083
Here are some related setups:
1. HREADY line is used to trigger MCU to read harmonics data
2. Since ADE7880 monitors one phase at a time, MCU sets to do 10 readings on one phase, then switch to next phase, read 10 readings, and so on. Is it a good practice, or  I should do more readings at one phase?
3. HCONFIG register, set the update rate to 512 ms (closed to 750 ms initial setting time)
Thank you very much for the help!
Karen
