ADV7611 ; how to transfer 720x480p60 using bt.656 ??
Question asked by luisfynn on Nov 13, 2014
Latest reply on Nov 14, 2014 by mattp
i'am luis in Korea
wish you would understand i am poor at ENGLISH.
ADV7611 receive 720X480P60 image(RASPBERRY PI)
and i wannt to send 720x480p60 using bt.656 to encoder( not used hs,vs,de)
below my code. plz check my code. I2C ADDRESS SETTING is skipped.
282 //----------------------------------------------------------------
283      0x98, 0x01, 0x06 ,  // Prim_Mode[3:0] & VFREQ[6:4]
284      0x98, 0x02, 0xF5 ,  // Auto CSC, YCrCb out, Set op_656 bit
285      0x98, 0x03, 0x42 ,  // 36 bit SDR 444 Mode 0
286      0x98, 0x04, 0x60 ,  // OP_CH_SEL & XTAL_FREQ_SEL
287      0x98, 0x05, 0x28 ,  // AV Codes OFF
288      0x98, 0x0B, 0x44 ,  // Power up part
289      0x98, 0x0C, 0x42 ,  // Power up part
290      0x98, 0x14, 0x7F ,  // Max Drive Strength
291      0x98, 0x15, 0x80 ,  // Disable Tristate of Pins
292      0x98, 0x19, 0x83 ,  // LLC DLL phase -720x480p 54Mhz
293      0x98, 0x33, 0x40 ,  // LLC DLL enable
294
295      0x44, 0xBA, 0x01 ,  // Set HDMI FreeRun
296
297      0x64, 0x40, 0x81 ,  // Disable HDCP 1.1 features
298
299      0x68, 0x9B, 0x03 ,  // ADI recommended setting
300 #if 0
301      0x68, 0xC1, 0x01 ,  // ADI recommended setting
302      0x68, 0xC2, 0x01 ,  // ADI recommended setting
303      0x68, 0xC3, 0x01 ,  // ADI recommended setting
304      0x68, 0xC4, 0x01 ,  // ADI recommended setting
305      0x68, 0xC5, 0x01 ,  // ADI recommended setting
306      0x68, 0xC6, 0x01 ,  // ADI recommended setting
307      0x68, 0xC7, 0x01 ,  // ADI recommended setting
308      0x68, 0xC8, 0x01 ,  // ADI recommended setting
309      0x68, 0xC9, 0x01 ,  // ADI recommended setting
310      0x68, 0xCA, 0x01 ,  // ADI recommended setting
311      0x68, 0xCB, 0x01 ,  // ADI recommended setting
312      0x68, 0xCC, 0x01 ,  // ADI recommended setting
313 #endif
314      0x68, 0x00, 0x08 ,  // Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
315      0x68, 0x02, 0x03 ,  // Enable Ports A & B in background mode
316
317      0x68, 0x83, 0xFC ,  // Enable clock terminators for port A & B
318      0x68, 0x6F, 0x0C,   // ADI recommended setting
319      0x68, 0x85, 0x1F,   // ADI recommended setting
320      0x68, 0x87, 0x70,   // ADI recommended setting
321      0x68, 0x8D, 0x04,   // LFG Port A
322      0x68, 0x8E, 0x1E,   // HFG Port A
323      0x68, 0x1A, 0x8A,   // unmute audio
324      0x68, 0x57, 0xDA,   // ADI recommended setting
325      0x68, 0x58, 0x01,   // ADI recommended setting
326
327      0x68, 0x75, 0x10,   // DDC drive strength
328      0x68, 0x90, 0x04,   // LFG Port B
329      0x68, 0x91, 0x1E,   // HFG Port B
330
331      0x98, 0x03, 0x00,   // 8-bit SDR ITU-656 mode
332      0x98, 0x19, 0xC3,   // LLC DLL phase (Matt)
333      0x98, 0x04, 0x42,   // OP_CH_SEL
334      0x98, 0x05, 0x2C,   // AV code on
