Reading of the actual Angle value of a ADIS16265 values does not fit
Question asked by ritchie on Nov 13, 2014
Latest reply on Nov 15, 2014 by ritchie
I am trying to get the actual angle value of the ADIS16265 and gets only a value back, which does
not is the absolute angle of degree i guess.
I am accessing the register "ADIS16265_ANGL_OUT" and getting a values back,
which looks like the value of "ADIS16265_GYRO_OUT".
I can read out without any problems, the product ID, temperature, Status and the voltage of the chip.
This is the code I use to convert the data:
   iValue=((SPIReceiveBuffer[0] & 0x3 ) << 8) + SPIReceiveBuffer[1];
   m_DigitalOrientationAngle=  (double)(iValue * 0.03663) * (M_PI / 180.0);
Do I have to init the chip in any way, that he will calculate the absolute angle, calculated by the chip ?
I also what to use only the resolution of 80 Deg / sec. and setup the chip with the code.
void    InitADIS16265ViaSPI(void)
    m_SPIByteToSend=4;
    m_SPIBytetoReceive=0;
    m_Active_SPI_Channel=SPI_SLAVE_GYRO;
    m_Active_Command=ADIS16265_SENS_AVG;
    SPISendBuffer[0]=ADIS16265_SENS_AVG+1;                    // Select the SENS_AVG Control register
    SPISendBuffer[1]=ADIS16265_SENS_AVG;
    SPISendBuffer[2]=01;                                    // Use 80°/sec instead of 320°/per sec. for range
    SPISendBuffer[3]=02;                                    // Number of taps in each stage; value of m in N = 2m (default)
        // Filter stage = 2
Is it correct, that I do not get a feedback of the chip, which I have to read ?
Thanks for any help
Best regards
Ritchie
