AD7799 read value from loadcell using Arduino mega 2560
Question asked by Zinedine on Nov 12, 2014
Latest reply on Nov 20, 2014 by jcolao
Hi everyone,
I'm a new fresher. My project is read value from loadcell using AD7799, I'm using Arduino control everything. But I have many trouble. I hope everyone can help me.
- AD7799 datasheet: http://www.analog.com/static/imported-files/data_sheets/AD7798_7799.pdf
- This is a analog device 24 bit.I'm using SPI communication.
- Attach is shematic board AD7799 that I designed
Below is my project in arduino: how about display or print value read in to LCD 16x2 or window arduino?
#include <Stdio.h>
#include<stdlib.h>
#include<SPI.h>
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define ulong unsigned long
#define uint unsigned int
#define uchar unsigned char
#define AD_CS 6
#define AD_SCK 7
#define AD_DIN 8
#define AD_DOUT 9
#define AD_RDY 9
void WriteByteToAd7799(unsigned char WriteData)
  pinMode(AD_SCK,OUTPUT);
  pinMode(AD_CS,OUTPUT);
  pinMode(AD_DIN,OUTPUT);
    unsigned char i;
    digitalWrite(AD_CS,LOW);//reset bit latch
    for(i=0;i<8;i++)
       // delayMicroseconds(10);
        digitalWrite(AD_SCK,LOW);
        //delayMicroseconds(10);
        if(WriteData&0x80)
        digitalWrite(AD_DIN,1);
        else digitalWrite(AD_DIN,0);
        WriteData=WriteData<<1 ;
        digitalWrite(AD_SCK,HIGH);
     digitalWrite(AD_CS,HIGH);//set bit latch
unsigned char ReadByteFromAd7799(void)
  //pinMode(AD_DOUT,INPUT);
  unsigned char i;
  unsigned char ReadData;
  ReadData=0;
  for(i=0;i<8;i++)
      ReadData=ReadData<<1;
        if(AD_DOUT)ReadData=ReadData+1;
     // digitalWrite(AD_DOUT,1);
      return(ReadData);
void WaiteRDY(void)
  unsigned int iint;
  iint=0;
  while(AD_RDY)
    iint++;
    if(iint>65530)
      //reset Ad7799
            WriteByteToAd7799(0xff);
            AD7799_Ini();
            break ;
void AD7799_Ini(void)
  //gain the 128
  WriteByteToAd7799(0x10);//communication register setting
  WriteByteToAd7799(0x37);//gain of 128
  WriteByteToAd7799(0x30);//channel 0
  //write mode register
  WriteByteToAd7799(0x08);//write to the communications register set operation for write mode register
  WriteByteToAd7799(0x80);
  WriteByteToAd7799(0x0A);
  WaiteRDY();//wait for RDY pin to go low
  //Write mode register is initialized to the full value of the calibration
  WriteByteToAd7799(0xA0);
  WaiteRDY();//wait for RDY pin to go Low
  //Mode 0, continuous Mode frequency 16.7Hz
  WriteByteToAd7799(0x00);
unsigned long ReadAd7799ConversionData(void)
  unsigned long ConverData;
  unsigned char ADSAT;
  unsigned char ErrNUM=0;
  WaiteRDY();
  WriteByteToAd7799(0x40);//write to the communications register set an operating STATUS register read status
  //WriteByteToAd7799(0xff);
  ADSAT = ReadByteFromAd7799();
  while((ADSAT&0x40)||(!ADSAT&0x08))
    // Prevent confusion timing resynchronization
    AD7799_Ini();
    WaiteRDY();
    WriteByteToAd7799(0xff);//pseudo write to the communications register clock for the Read Status Register
    //ADSAT=ReadByteFromAd7799();//read the rêcived data
    ErrNUM++;
    if(ErrNUM>5)break;
    WriteByteToAd7799(0x58);// write to the communications register set an operating continuously read data register
    WaiteRDY();
  if(!AD_RDY)
  ConverData=0;
  //Read Conversion Result from AD7799's Data Register
  ConverData=ReadByteFromAd7799();
  ConverData=ConverData<<8;
  //WriteByteToAd7799 (0xff); // pseudo write to the communications register clock for the read data register Register
  ConverData=ReadByteFromAd7799()+ConverData;
  //ConverData=ConverData+SPDR;
  //WriteByteToAd7799 (0xff); //pseudo write to the communications register clock for the read data register Register
  if(ErrNUM>5)return(0);
  else return ConverData;
void setup() {
   Serial.begin(115200);
  //SPCR = 0x5E ;//SPI control registers, interrupt disable the SPI is enabled, the previous high, host mode, the clock idles high, trailing edge trigger Shift, clock divider 64
  //SPSR = 0x00 ;//clear interrupt flag
  //lcd.begin(16, 2);
  // Print a message to the LCD.
  //lcd.print("ANALOG READING:");
//UCIL temp;
unsigned char temp1;
void loop() {
while(1)
temp1=ReadAd7799ConversionData();
//lcd.setCursor(1,0);
//lcd.print(temp1);
//lcd.print("         ");
Serial.println(temp1);
