Booting from SD card: Zed with FMCOMMS1!
Question asked by Jetmiri on Nov 12, 2014
Latest reply on Nov 18, 2014 by CsomI
Dear all,
I am trying to use Zedboard with FMCOMMS1. The hdl design that I am using is the design given at the demo QPSK Digital Up/Down-Converter Demo (http://zedboard.org/support/design/1521/11). In this design the hdl design of FMCOMMS1 version 1 of 23.08.2013 is used. I can create the bit stream in XPS even though that in beginning there is one warnings saying that WARNING:EDK:1954 - No Top-level Input clock for the design.  No errors are shown during the bit stream generation. After that I create the boot.bin file using the u-boot.elf from the SD card I received with FMCOMMS1 from the folder cf_xcomm_zed.
I try to boot from SD card using the uImage and the same devicetree.dtb from the folder cf_xcomm_zed. But however the linux runs but I can not see anything on my monitor. So it seems that the HDMI transmitter is not working somehow. I receive also the error:
adau1761 0-003b: ASoC: AIFOUT Capture Mux DAPM update failed: -110
adau1761 0-003b: ASoC: DAC Playback Mux DAPM update failed: -110
adau1761 0-003b: ASoC: Right LR Playback Mixer DAPM update failed: -110
I have to pint it out that nothing in the HDL design is changed, an QPSK digital up converter and a converter are inserted in tx/rx side respectively.
This is the what is shown in the terminal after I boot from SD card:
U-Boot 2012.10 (Mar 22 2013 - 14:07:04)
DRAM:  512 MiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
SF: Detected S25FL256S with page size 64 KiB, total 32 MiB
SF: Warning - Only lower 16MB is accessible in 3 byte addressing mode
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading uImage
2972816 bytes read
reading devicetree.dtb
14696 bytes read
reading uramdisk.image.gz
** Unable to read "uramdisk.image.gz" from mmc 0:1 **
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.13.0-68980-gbcc97b8
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2972752 Bytes = 2.8 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 1fb4e000, end 1fb54967 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 3.13.0-68980-gbcc97b8 (michael@mhenneri-D04) (gcc version 4.7.2 (Sourcery CodeBench Lite 2012.09-104) ) #1326 SMP PREEMPT Thu Mar 13 13:53:23 CET 2014
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Xilinx Zynq ZED
bootconsole [earlycon0] enabled
cma: CMA: reserved 40 MiB at 1d000000
Memory policy: Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c09ec000 s7616 r8192 d12864 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait devtmpfs.mount=0
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 472572K/524288K available (3950K kernel code, 237K rwdata, 1484K rodata, 183K init, 127K bss, 51716K reserved, 0K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0556d54   (5436 kB)
      .init : 0xc0557000 - 0xc0584dc0   ( 184 kB)
      .data : 0xc0586000 - 0xc05c14c0   ( 238 kB)
       .bss : 0xc05c14cc - 0xc05e14a4   ( 128 kB)
Preemptible hierarchical RCU implementation.
        Dump stacks of tasks blocking RCU-preempt GP.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:16 nr_irqs:16 16
slcr mapped to e0802000
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207951633ns
timer #0 at e0804000, irq=43
Console: colour dummy device 80x30
Calibrating delay loop... 1325.46 BogoMIPS (lpj=6627328)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x3bb3a0 - 0x3bb3d4
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 512 kB
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
zynq-gpio e000a000.gpio: gpio at 0xe000a000 mapped to 0xe080e000
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm fffc0000.ps7-ocm: ZYNQ OCM pool: 256 KiB @ 0xe0880000
zynq-ocm fffc0000.ps7-ocm: can't request region for resource [mem 0xfffc0000-0xffffffff]
zynq-ocm: probe of fffc0000.ps7-ocm failed with error -16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource ttc_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
msgmni has been set to 1002
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-2364208
dma-pl330 f8003000.ps7-dma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.uart: ttyPS0 atconsole [ttyPS0] enabled
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to e0814000
[drm] Initialized drm 1.1.0 20060810
platform 70e00000.axi_hdmi: Driver axi-hdmi requests probe deferral
brd: module loaded
loop: module loaded
zynq-qspi e000d000.qspi: master is unqueued, this is deprecated
m25p80 spi32766.0: found s25fl256s1, expected m25p80
m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
5 ofpart partitions found on MTD device spi32766.0
Creating 5 MTD partitions on "spi32766.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000002000000 : "spare"
zynq-qspi e000d000.qspi: at 0xE000D000 mapped to 0xE0816000, irq=51
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
zynq-ehci zynq-ehci.0: Xilinx Zynq USB EHCI Host Controller
zynq-ehci zynq-ehci.0: new USB bus registered, assigned bus number 1
zynq-ehci zynq-ehci.0: irq 53, io mem 0x00000000
zynq-ehci zynq-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
usb 1-1: new low-speed USB device number 2 using zynq-ehci
adv7511 0-0039: Failed to write 98 = 3: -110
adv7511: probe of 0-0039 failed with error -110
at24 1-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
at24 1-0054: 256 byte 24c02 EEPROM, writable, 1 bytes/write
zynq-wdt f8005000.swdt: Xilinx Watchdog Timer at e081c000 with timeout 10s
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-arasan e0100000.sdhci: dummy supplies not allowed
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
input: PS2 to USB AdapterA3 as /devices/amba.1/e0002000.usb/zynq-ehci.0/usb1/1-1/1-1:1.0/input/input0
hid-generic 0003:10D5:0004.0001: input,hidraw0: USB HID v1.10 Keyboard [PS2 to USB AdapterA3] on usb-zynq-ehci.0-1/input0
mmc0: new high speed SDHC card at address e624
mmcblk0: mmc0:e624 SD08G 7.40 GiB
input: PS2 to USB AdapterA3 as /devices/amba.1/e0002000.usb/zynq-ehci.0/usb1/1-1/1-1:1.1/input/input1
mmcblk0: p1 p2
hid-generic 0003:10D5:0004.0002: input,hidraw1: USB HID v1.10 Mouse [PS2 to USB AdapterA3] on usb-zynq-ehci.0-1/input1
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
platform 79020000.cf-ad9643-core-lpc: Driver cf_axi_adc requests probe deferral
spi spi32765.1: Driver ad9467 requests probe deferral
spi32765.6 supply vcc not found, using dummy regulator
spi_master spi32765: failed to transfer one message from queue
iio iio:device1: write failed (-110)
ad8366: probe of spi32765.6 failed with error -110
spi32765.3 supply vcc not found, using dummy regulator
ad9523: probe of spi32765.3 failed with error -110
ad9548: probe of spi32765.2 failed with error -110
ERROR: could not get clock /fpga-axi@0/i2c@41620000/spi_xcomm0@58/adf4351-rx-lpc@4:clkin(0)
spi spi32765.4: Driver adf4350 requests probe deferral
ERROR: could not get clock /fpga-axi@0/i2c@41620000/spi_xcomm0@58/adf4351-tx-lpc@5:clkin(0)
spi spi32765.5: Driver adf4350 requests probe deferral
platform 74204000.cf-ad9122-core-lpc: Driver cf_axi_dds requests probe deferral
ad9122 spi32765.0: Unrecognized CHIP_ID 0xFFFFFF92
adv7511-hdmi-snd adv7511_hdmi_snd.4: ASoC: CODEC (null) not registered
platform adv7511_hdmi_snd.4: Driver adv7511-hdmi-snd requests probe deferral
zed-adau1761-snd zed_sound.5: adau-hifi <-> 77600000.axi-i2s mapping ok
TCP: cubic registered
Registering SWP/SWPB emulation handler
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
ALSA device list:
  #0: ZED ADAU1761
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
Freeing unused kernel memory: 180K (c0557000 - c0584000)
ureadahead main process (753) terminated with status 5able
Last login: Thu Jan  1 00:00:51 UTC 1970 on tty1
Welcome to Linaro 12.11 (GNU/Linux 3.13.0-68980-gbcc97b8 armv7l)
* Documentation:  https://wiki.linaro.org/
root@linaro-ubuntu-desktop:~# adau1761 0-003b: ASoC: AIFOUT Capture Mux DAPM update failed: -110
adau1761 0-003b: ASoC: Left LR Playback Mixer DAPM update failed: -110
