ad9364 TX VCO lock bit
Question asked by mince on Nov 6, 2014
Latest reply on Nov 7, 2014 by mince
I calibrated the TX LO of AD9364 for more than 8 frequencies. I saved the calibration results on the baseband processor. The difference between the minimum and maximum frequency that I have calibrated and locked at startup is about ~ 250 MHz.
I am loading the calibrated values into the TX fast lock profiles. Then, I am selecting the current operating frequency from TX fast lock profile table by selecting the index. The RF output of AD9364 is set to desired frequency after this operation.
However, I could not observe the falling of TX lock signal at control outputs even if I change the LO frequency more than 200 MHz when using fast lock profiles.
If the LO frequency is changed directly by baseband processor, I am observing the falling of TX lock signal at the control output bit7.  (Register 0x035 = 0x01 and Register 0x36 = 0xFF).
Could you help me in order to understand this situation ?
Why the RFPLL is not enter un-locked mode ?
In addition to, is there any method of measuring the frequency hopping time of AD9364 when using fast lock method ?
Best Regards,
Mustafa iNCE
