Analog Devices parts required for ADC and DAC operation
Question asked by maga123 on Oct 13, 2010
I am having following requirements for my design. I need to select the ADC and DAC chips. Could you please suggest the Analog Devices products for my requirements.
Please send the part numbers immediately.
Analog Input Characteristics
  • Type: Sigma-Delta ADC
  • Channel Count : 2 Channels
  • Channel Configuration :      Single ended
  • Supported Signal Analog      Bandwidth : 100 kHz
  • Resolution : 16 Bits on      each channel
  • ADC Sampling Rate : up to      200 kilo samples per second per channel (not more than 200ksps)
  • Support for under sampling      applications
  • Sampling Clock: Internal,      tunable in entire range in 1 Hz step.
  • Data Format : 2's      compliment Binary
  • SINAD(dB) : better than 80
  • SFDR : better than 90 dB
  • Input Voltage       Range Bipolar : +/‐2.5V,      50 Ohms
  • Operation: Independent      Operation of each channel, option for continuous as well as transient data      capture, sufficient FIFO and data transfer to processor without overhead      on processor
  • Acquisition Control:      Internal (software) trigger
  • Applications: Radar,      Sonar
  • Temperature: -40C to +85C
Analog Output Characteristics
  • Channel Configuration :      Single Ended
  • Supported Signal Analog      Bandwidth: 100 kHz
  • DAC Sampling Rate: up to      300 kilo samples per second per channel (not more than 300ksps)
  • Output Mode : Independent
  • Data Format: 2's      compliment Binary
  • Output Voltage       Range Bipolar: ±2.5V,      50 ohms
  • Operation: Independent      Operation of each channel, option for continuous as well  as transient data transfer, sufficient      FIFO and data transfer from processor       without overhead on processor.
N.Magalingam
Senior Hardware Engineer
Cornet Technology,
Chennai,
India
Mobile:+91-9994867369
