why can't I read edid of adv7611,while the other registers are all normal?
Question asked by wriyangzhi@163.com on Nov 4, 2014
Latest reply on Nov 6, 2014 by GuenterL
A new project,I could correctly set and read all registers except edid, also a pc couldn't find the adv7611,maybe the edid registers are not set correctly,please help me.
unsigned char script[] = {
  0x98, 0xFF, 0x80,    // I2C reset
0x98, 0xF4, 0x80,  // CEC SLAVE ADDRESS
0x98, 0xF5, 0x7C,  // INFOFRAME SLAVE ADDRESS
0x98, 0xF8, 0x4C,  // DPLL SLAVE ADDRESS
0x98, 0xF9, 0x64,  // KSV SLAVE ADDRESS
0x98, 0xFA, 0x6C,  // EDID SLAVE ADDRESS
0x98, 0xFB, 0x68,  // HDMI SLAVE ADDRESS
0x98, 0xFD, 0x44,  // CP SLAVE ADDRESS
0x98, 0x01, 0x05,  // vertical frequency = 60Hz,Prim_Mode =101b HDMI-Comp
0x98, 0x02, 0xF5,  // Auto CSC, no YPbPr colorspace conversion,
       // set the output range of the digital data = limited range (16 to 235), YCrCb out
0x98, 0x03, 0x80,  // 0x80 = 16-bit ITU-656 SDR mode; 0x20 = 8-bit 4:2:2 DDR mode (ITU-656 mode)
0x98, 0x04, 0x60,  // 011 - P[23:16] V/R, P[15:8] Y/G, P[7:0] U/CrCb/B ; XTAL = 27 MHz
0x98, 0x05, 0x28,  // DE output on the FIELD/DE pin ; AV Codes Off
0x98, 0x0B, 0x44,  // Powers up CP and digital sections of HDMI block; Powers up XTAL buffer to the digital core
0x98, 0x0C, 0x42,  // Chip is operational,Disables power save mode,Powers up the clock to the CP core,Powers up the pads of the digital output pins
0x98, 0x14, 0x7F,  // High drive strength of data output drivers;output pixel clock out signal on the LLC pin,
                      // synchronization pins, HS, VS/FIELD, FIELD/DE;audio output interface pins (AP0, AP1/I2S_TDM, AP2 ... AP5).
0x98, 0x15, 0x80,  // Disable Tristate of Pins
0x98, 0x19, 0x83,  // LLC DLL phase
0x98, 0x33, 0x40,  // LLC DLL enable
0x44, 0xBA, 0x01,  // Set HDMI FreeRun when the TMDS clock is not detected on the selected HDMI port
0x64, 0x40, 0x81,  // Disable HDCP 1.1 features
0x68, 0x9B, 0x03,  // ADI recommended setting
0x68, 0xC1, 0x01,  // ADI recommended setting
0x68, 0xC2, 0x01,  // ADI recommended setting
0x68, 0xC3, 0x01,  // ADI recommended setting
0x68, 0xC4, 0x01,  // ADI recommended setting
0x68, 0xC5, 0x01,  // ADI recommended setting
0x68, 0xC6, 0x01,  // ADI recommended setting
0x68, 0xC7, 0x01,  // ADI recommended setting
0x68, 0xC8, 0x01,  // ADI recommended setting
0x68, 0xC9, 0x01,  // ADI recommended setting
0x68, 0xCA, 0x01,  // ADI recommended setting
0x68, 0xCB, 0x01,  // ADI recommended setting
0x68, 0xCC, 0x01,  // ADI recommended setting
0x68, 0x00, 0x00,  // Set HDMI Input Port A
0x68, 0x83, 0xFE,  // Enable clock terminator for port A
0x68, 0x6F, 0x0C,  // ADI recommended setting
0x68, 0x85, 0x1F,  // ADI recommended setting
0x68, 0x87, 0x70,  // ADI recommended setting
0x68, 0x8D, 0x04,  // LF gain equalizer settings for dynamic mode range 1
0x68, 0x8E, 0x1E,  // HF gain equalizer settings for dynamic mode range 1
0x68, 0x1A, 0x8A,  // unmute audio
0x68, 0x57, 0xDA,  // ADI recommended setting
0x68, 0x58, 0x01,  // ADI recommended setting
0x68, 0x03, 0x98,    // DIS_I2C_ZERO_COMPR
0x68, 0x75, 0x10,  // DDC drive strength
0xFF };
void I2C_write_tab_new( unsigned char *script )
do {
  i2cWriteReg8bb(*script, *(script+1), *(script+2));
   script += 3;
} while (*script != 0xFF)  ;
unsigned char vga_edid[256]
   {0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,   //00
0x06, 0x8F, 0x07, 0x11, 0x01, 0x00, 0x00, 0x00,   //08
0x17, 0x11, 0x01, 0x03, 0x80, 0x0C, 0x09, 0x78,   //10
0x0A, 0x1E, 0xAC, 0x98, 0x59, 0x56, 0x85, 0x28,   //18
0x29, 0x52, 0x57, 0x00, 0x00, 0x00, 0x01, 0x01,   //20
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,   //28
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x8C, 0x0A,   //30
0xD0, 0x8A, 0x20, 0xE0, 0x2D, 0x10, 0x10, 0x3E,   //38
0x96, 0x00, 0x81, 0x60, 0x00, 0x00, 0x00, 0x18,   //40
0x01, 0x1D, 0x80, 0x18, 0x71, 0x1C, 0x16, 0x20,   //48
0x58, 0x2C, 0x25, 0x00, 0x81, 0x49, 0x00, 0x00,   //50
0x00, 0x9E, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x56,   //58
0x41, 0x2D, 0x31, 0x38, 0x30, 0x39, 0x41, 0x0A,   //60
0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0xFD,   //68
0x00, 0x17, 0x3D, 0x0D, 0x3E, 0x11, 0x00, 0x0A,   //70
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x01, 0x1C,   //78
0x02, 0x03, 0x34, 0x71, 0x4D, 0x82, 0x05, 0x04,   //80
0x01, 0x10, 0x11, 0x14, 0x13, 0x1F, 0x06, 0x15,   //88
0x03, 0x12, 0x35, 0x0F, 0x7F, 0x07, 0x17, 0x1F,
0x38, 0x1F, 0x07, 0x30, 0x2F, 0x07, 0x72, 0x3F,
0x7F, 0x72, 0x57, 0x7F, 0x00, 0x37, 0x7F, 0x72,
0x83, 0x4F, 0x00, 0x00, 0x67, 0x03, 0x0C, 0x00,
0x10, 0x00, 0x88, 0x2D, 0x00, 0x00, 0x00, 0xFF,
0x00, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x00, 0x00,
0x00, 0xFF, 0x00, 0x0A, 0x20, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20,
0x00, 0x00, 0x00, 0xFF, 0x00, 0x0A, 0x20, 0x20,
0x20, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xDA,
void i2c_vga_edid_read(unsigned char *ptr)
  unsigned int addr=0;
unsigned char i=0;
for (addr=0; addr<256; addr++)
  i2cReadReg8bb(0xA0, addr, (ptr+addr));
void i2c_program_edid(unsigned char *data, int length)
unsigned long i;
i2cWriteReg8bb(0x64, 0x77, 0x00);
i2cWriteReg8bb(0x64, 0x74, 0x00);
for (i=0; i<length; i++)
  i2cWriteReg8bb(0x6C, i, data[i]);
for (i=0; i<800000; i++); // delay for HPA
i2cWriteReg8bb(0x64, 0x52, 0x20);
i2cWriteReg8bb(0x64, 0x53, 0x00);
i2cWriteReg8bb(0x64, 0x70, 0x9E);
i2cWriteReg8bb(0x64, 0x74, 0x03);
void main(void)
unsigned char edid_save[256],tt[6];
i2cWriteReg8bb(0x98, 0xFF, 0x80); // RESET part and wait (no ACK after reset)
wait2();
I2C_write_tab_new(script); // program the part
i2c_program_edid(vga_edid, 256);
for(j=0;j<6;j++)
  i2cReadReg8bb(0x98, 0x01+j,tt+j) ;//the reading value is coincident to the setting value
i2c_vga_edid_read(edid_save);  // all the read edid value is 0xff
