BF537 ,getting Nothing on CLKOUT
Question asked by ali on Oct 12, 2010
Latest reply on Oct 15, 2010 by ali
In my previous post i mentioned that I had a reset timing problem which kept me from getting my JTAG working.
That reset problem has been fixed, the JTAG is working, i'm using Wiggler .
Now the problem is as follows;-
when i power up the circuit, i get nothing on CLKOUT but a 1.2V DC . Whereas it should be a 50Mhz clock (correct me if am wrong).
I am getting CLKBUF 25Mhz perfect. Have checked the voltages (1.2V working fine) JTAG interface is working .
I've checked to make sure that i have a pulled up "BG" signal.
Are there any other signals i should check which would lead me to some conclusion ?
P.S I hope i am right in concluding from Hardware ref manual and data sheet that I should get a 50Mhz Clock on CLKOUT pin right after power up, without a need to run any code. (correct me if am wrong)
