7611 12bit 422 DDR Mode
Question asked by GiantDwarf on Oct 31, 2014
Latest reply on Nov 4, 2014 by GiantDwarf
Hello all,
we are using the AVD7611 HDMI RX and try to configure it for 12bit DDR 4:2:2 Mode 2. The 7611 is connected to our FPGA.
Our problem is that no CbCr values are getting transferred. Luminance is fine but the colors are missing.
Thanks for any help or information.
Here is a snip of the configuration:
---snip---
echo "Configuration ADV7611 General Settings"
io_set 0x00 0x1E
hdmi_set 0x48 0x01  # disable cable reset DIS_CABLE_DET_RST
io_set 0x01 0x06 #Primary Mode = 110b HDMI GR
io_set 0x03 0x2A # OP_FORMAT_SEL[7:0], 12-bit DDR 4:2:2 Mode 2
io_set 0x05 0x28 #AVCode off
io_set 0x06 0xA0 #Invert VS,HS pins
io_set 0x0B 0x44 #Power up part
io_set 0x0C 0x42 #Power up part
io_set 0x14 0x7F #Max Drive Strength
io_set 0x15 0x80 #Disable Tristate of Pins
io_set 0x19 0x82 #LLC DLL phase
io_set 0x33 0x40 #LLC DLL enable
cp_set 0xBA 0x01 #Set HDMI FreeRun
rep_set 0x40 0x81 #Disable HDCP 1.1 features
echo "Configuration ADV7611 recommend settings"
hdmi_set 0x9B 0x03 #ADI recommended
hdmi_set 0xC1 0x01 #ADI recommended
hdmi_set 0xC2 0x01 #ADI recommended
hdmi_set 0xC3 0x01 #ADI recommended
hdmi_set 0xC4 0x01 #ADI recommended
hdmi_set 0xC5 0x01 #ADI recommended
hdmi_set 0xC6 0x01 #ADI recommended
hdmi_set 0xC7 0x01 #ADI recommended
hdmi_set 0xC8 0x01 #ADI recommended
hdmi_set 0xC9 0x01 #ADI recommended
hdmi_set 0xCA 0x01 #ADI recommended
hdmi_set 0xCB 0x01 #ADI recommended
hdmi_set 0xCC 0x01 #ADI recommended
hdmi_set 0x00 0x00 #Set HDMI Input Port A
hdmi_set 0x83 0xFE #Enable clock terminator for port A
hdmi_set 0x6D 0x80 #Enable TDM Mode
hdmi_set 0x6F 0x0C #ADI recommended setting
hdmi_set 0x85 0x1F #ADI recommended setting
hdmi_set 0x87 0x70 #ADI recommended setting
hdmi_set 0x8D 0x04 #LFG
hdmi_set 0x8E 0x1E #HFG
hdmi_set 0x1A 0x8A #unmute audio
hdmi_set 0x57 0xDA #ADI recommended setting
hdmi_set 0x58 0x01 #ADI recommended setting
hdmi_set 0x75 0x10 #DDC drive strength
echo "Setup EDID".
----snap---
