BF518 TWI (AD7998) issue (sequence mode)
Question asked by BlueIceScream on Oct 27, 2014
Latest reply on Dec 10, 2014 by Suraj
Hi to all.
I have some issue with AD7998 ADC.
AD7998 adc supports several modes and use twi for data transfering.
When i use single conversion mode (conversion by command) all works fine.
When i use sequence mode (conversion all channels one by one) i get same values for all channels.
this is my code:
#include <adi_types.h>
#include <stdio.h>
#include "adi_ssl_Init.h"
#include "AD7998.h"
void Callback(void *ClientHandle, u32 Event, void *pArg);
const adi_twi_bit_rate rate = { .frequency = 100, .duty_cycle = 50 };
static bool prepareReadyStatus = false;
static bool readSingleReadyStatus = false;
static bool readMultiReadyStatus = false;
u8 OutboundData[10];
u8 InboundData[22];
//Table of configuration
ADI_DEV_CMD_VALUE_PAIR TWIConfigurationTable[] = { // configuration table for the TWI driver
            {ADI_DEV_CMD_SET_DATAFLOW_METHOD,        (void *)ADI_DEV_MODE_SEQ_CHAINED},
            {ADI_TWI_CMD_SET_FIFO,                    (void *)0x0000},
            {ADI_TWI_CMD_SET_RATE,                    (void *)(&rate)},
            {ADI_TWI_CMD_SET_LOSTARB,                (void *)1},
            {ADI_TWI_CMD_SET_ANAK,                    (void *)0},
            {ADI_TWI_CMD_SET_DNAK,                    (void *)0},
            {ADI_DEV_CMD_END,                        NULL}
ADI_DEV_DEVICE_HANDLE     TWIDeviceHandle;
ADI_DEV_SEQ_1D_BUFFER    OutboundBuffer;
ADI_DEV_SEQ_1D_BUFFER    InboundBuffer;
// init AD7998 device and twi system
int AD7998_init(void)
    u32 result;
    result = adi_dev_Open(
                adi_dev_ManagerHandle,
                &ADITWIEntryPoint,
                0,  // TWI Device Number
                NULL, // Client Handle ( passed to call back function )
                &TWIDeviceHandle,
                ADI_DEV_DIRECTION_BIDIRECTIONAL,
                NULL, // DMA Handle (TWI has no DMA)
                NULL, //Handle to the deferred callback service deferred.
                Callback // Call Back Function.
    if (result) {
        printf("AD7998 says:\tCan't open twi device\n");
        return -1;
    // output buffer common setup
    OutboundBuffer.Buffer.Data = &OutboundData[0];
    OutboundBuffer.Buffer.ElementWidth = 1;
    OutboundBuffer.Buffer.ProcessedFlag = NULL;
    OutboundBuffer.Buffer.ProcessedElementCount = NULL;
    OutboundBuffer.Direction = ADI_DEV_DIRECTION_OUTBOUND;
    // input buffer common setup
    InboundBuffer.Buffer.Data = &InboundData[0];
    InboundBuffer.Buffer.ElementWidth = 1;
    InboundBuffer.Buffer.ProcessedFlag = NULL;
    InboundBuffer.Buffer.ProcessedElementCount = NULL;
    InboundBuffer.Direction = ADI_DEV_DIRECTION_INBOUND;
    // configure twi device
    result = adi_dev_Control(TWIDeviceHandle, ADI_DEV_CMD_TABLE, TWIConfigurationTable);
    if (result) {
        printf("AD7998 says:\tCan't configure twi device\n");
        return -1;
    // start dataflow
    adi_dev_Control(TWIDeviceHandle, ADI_DEV_CMD_SET_DATAFLOW, (void *)TRUE);
    return 0;
// Prepare device to work in sequence mode
// function blocks thread
void AD7998_prepare()
    // set value for configuration register
    // all channels set to 1; fltr set to 1
    OutboundData[0] = CONFIGURATION_REG;
    OutboundData[1] = 0x03;
    OutboundData[2] = 0xFA;
    // setup output buffer
    OutboundBuffer.Buffer.ElementCount = 3;
    OutboundBuffer.Buffer.CallbackParameter = (void *)CMD_PREPARE_PARAM;
    OutboundBuffer.Buffer.pNext = NULL;
    OutboundBuffer.Buffer.pAdditionalInfo = (void *)AD7998_ADDR;
    adi_dev_SequentialIO(TWIDeviceHandle, ADI_DEV_SEQ_1D,
                        (ADI_DEV_BUFFER *)&OutboundBuffer);
    // wait before data will be sent
    while (!prepareReadyStatus);
// read data from AD7998 channel
// return reading data
// this function block thread!!!
u32 AD7998_readSingle(u8 channel)
    // set channel for reading
    OutboundData[0] = channel;
    // send data to address point register
    // (4MSB is channel num) (4LSB is conversation register address)
    OutboundBuffer.Buffer.ElementCount = 1;
    OutboundBuffer.Buffer.CallbackParameter = (void *)0;
    OutboundBuffer.Buffer.pNext = &InboundBuffer.Buffer;
    // we receive 2 bytes (12 bit ADC)
    InboundBuffer.Buffer.ElementCount = 2;
    InboundBuffer.Buffer.CallbackParameter = (void *)CMD_READSINGLE_PARAM;
    InboundBuffer.Buffer.pNext = NULL;
    InboundBuffer.Buffer.pAdditionalInfo = (void *)AD7998_ADDR;
    // wait before operations complete
    while (!readSingleReadyStatus);
    // pack result
    return (((InboundData[0] & 0x0F)<<8) | InboundData[1]);
// read sequense data from AD7998 channels
// return pointer to readed data
void AD7998_readMulti(u32 *ADCResultsData)
    u32 i;
    // set value for sequence convert
    // this value will be stored in address point register
    OutboundData[0] = 0x70;//SEQUENCE_CONVERT;
    // we have to receive 12 bytes (12 bit from conversion register x 6 channels)
    InboundBuffer.Buffer.ElementCount = 12;
    InboundBuffer.Buffer.CallbackParameter = (void *)CMD_READMULTI_PARAM;
    // wait before all data will be received
    while (!readMultiReadyStatus);
    // prepare results
    for (i=0; i<12; i+=2)
        ADCResultsData[i/2] = ((InboundData[i] & 0x0F)<<8) | InboundData[i+1];
    char param = (char)pArg;
    if (param == CMD_PREPARE_PARAM && Event==ADI_DEV_EVENT_BUFFER_PROCESSED) {
        prepareReadyStatus = true;
    else if (param == CMD_READMULTI_PARAM && Event==ADI_DEV_EVENT_BUFFER_PROCESSED) {
        readMultiReadyStatus = true;
    else if (param == CMD_READSINGLE_PARAM && Event==ADI_DEV_EVENT_BUFFER_PROCESSED) {
        readSingleReadyStatus = true;
I know that for every channel AD7998 starts conversion because some values (that i got) sometimes different. For example:
Vin1 = 0x0489
Vin2 = 0x0489
Vin3 = 0x0489
Vin4 = 0x0489
Vin5 = 0x048A !!!!!  (this is because i change Vin1 input during sequence conversation)
Vin6 = 0x048A !!!!!
Vin7 = 0x048A !!!!!
Seems that AD7998 do conversion in one channel, but must do conversion for all channels (for channels thats have logical 1 in Configuration register).
Single read method works fine. But i want know where i has error or may be this is AD7998 issue.
