Debugging Linux application using ZedBoard and FMCOMMS2
Question asked by cpmullins on Oct 21, 2014
Latest reply on Oct 29, 2014 by mhennerich
I have just started using a ZedBoard + FMCOMMS2 eval kit with Vivado 2013.4 installed.
If I use the ZedBoard SD card, I can create a simple Linux application project and debug it as a Remote ARM Linux Application (logged in with user ID: root and Password: root).
If I use the Analog Devices SD card (January 2014 build) and try to do the same thing with the password set to 'analog', I see something like:
739-gdb-set confirm off
739^done
(gdb)
740-gdb-set width 0
740^done
(gdb)
741-gdb-set height 0
741^done
(gdb)
742-interpreter-exec console echo
742^done
(gdb)
743-gdb-show prompt
743^done,value="(gdb) "
(gdb)
744-gdb-set target-async 0
744^done
(gdb)
745-gdb-set auto-solib-add on
745^done
(gdb)
746-gdb-set stop-on-solib-events 0
746^done
(gdb)
747-gdb-set stop-on-solib-events 1
747^done
(gdb)
748-target-select remote 192.168.1.10:1234
~"Ignoring packet error, continuing...\n"
warning: unrecognized item "timeout" in "qSupported" response
&"warning: unrecognized item \"timeout\" in \"qSupported\" response\n"
=thread-group-started,id="i1",pid="42000"
=thread-created,id="1",group-id="i1"
=thread-group-exited,id="i1"
748^error,msg="Malformed response to offset query, timeout"
(gdb)
749-gdb-exit
749^exit
Am I missing something really simple or is there a configuration step I need to perform first before I can use the debugger?
Chris
