Question about HMC632LP5E and HMC736LP4E
Question asked by Kazu on Oct 20, 2014
Latest reply on Nov 17, 2014 by MRichardson
We have some questions about the HMC632LP5E and the HMC736LP4E.
We would like to get only the 7.5GHz output using RFOPUT/2 function setting Fo=15GHz. We would not like
3.75GHz (RFOUT/4) in this case.
- HMC632LP5E
  In order to get only 7.5GHz output, the RFOUT and the RFOUT/4 pins will be terminated.
  Also the Vcc(Dig) pin will be open to stop the prescaler for RFOUT/4.
  We will use only the RFOPUT/2 pin. In such case, Fo/4 harmonics(3.75GHz) will appear from the RFOUT/2 pin?
  If yes, what is the ouput power of the Fo/4 from the RFOUT/2 pin?
  Is it 25dBc written in the datasheet?  (Harmonics/Subharmonics: 1/2 25dBc typ)
  Fo/8 harmonics will also appear?
- HMC736LP4E
   In order to get only 7.5GHz output, the RFOUT will be terminated. We will use only the RFOUT/2 pin.
   If yes, what is the ouput power of the Fo/4 from the RFOUT/2 pin? Fo/8 harmonics will also appear?
Best Regards,
