ADV7619 API I2C Field Read/Write
Question asked by hkhan@evertz.com on Oct 15, 2014
Latest reply on Oct 17, 2014 by Poornima
I am using provided API which contains following function that has to be implemented by application designer. Can someone explain what these two statement means?
      "Set to 0 if FieldVal is in correct position of the reg"
      "If FieldVal is already in the correct position"
BitPos is passed in as a parameter so I can't imagine a scenario where user would ignore it by setting it to 0.
* Write up to 8-bit field to a single 8-bit register
*              ________
* Example     |___****_|  Mask = 0x1E     BitPos = 1
* Entry:   DevAddr = Device Address
*          RegAddr = 8-bit register address
*          Mask    = Field mask
*          BitPos  = Field LSBit position in the register (0-7)
*                    Set to 0 if FieldVal is in correct position of the reg
*          FieldVal= Value (in the LSBits) of the field to be written
*                    If FieldVal is already in the correct position (i.e.,
*                    does not need to be shifted,) set BitPos to 0
* Return:  None
void ATV_I2CWriteField8 (UCHAR DevAddr, UCHAR RegAddr, UCHAR Mask,
                         UCHAR BitPos, UCHAR FieldVal)
