FIR Accelerator 21489, errata?
Question asked by AntonioJ on Oct 3, 2014
Latest reply on Jan 16, 2015 by Mitesh
I am trying to implement a simple FIR filter using the accelerator. However there are two things that I observe that do not match the description in the datasheet.
I am trying to implement this filter in the process_audio() function, which is called periodically at the sample rate of the application.
I am trying to filter in a sample by sample basis, so, according to the documentation, I select a window size of 1 (W = 1). I place the new input sample in the memory location pointed by IIFFIR (which is x[n – (N – 1)] according to the Processor HW Ref). This is a single rate filter so, after running the filter, I expect the IIFFIR to be IIFIR+W.  (IIFIR+1) in my case, as stated in the documentation. I find that if I select W=1 in the FIRCTL2 (in the TCB), the actual IIFIR is incrementing in 2s, if I select W=0 in this register, IIFIR increments by 1, which is what I need to use this value as a pointer to the delay line. I need some clarifying on this. Is the documentation wrong?
I also find that the output from the filter is slightly wrong. When I test the impulse response, I observe that the last coefficient coming out first, and then the rest of the coefficients starting by C[0] (look at the attached plot. 0.9 is the last coefficient, C[0] is 0.1, C[1] is 0.2, C[2] is -0.3). I would like to know if there are any mistakes in my code or whether the accelerator does not work as described. Your help is much appreciated.
Antonio
Here's the code:
#define TAPS_15k 92
#define WINDOW_15k 1
float pm coeffs_filt15k[TAPS_FILT15K] = {
#include "FILTER15KCOEFFS.dat"
+0.100007346683829030,
+0.200102142422956310,
-0.300188628018322800,
+0.000163361617938940,
+0.000054138481918590,
… … … (impulse response of the filter)
-0.000188628018322800,
+0.700102142422956310,
+0.800007346683829030,
+0.900007346683829030
float output_filt15kR[92];
float dm input_filt15kR[92];
int FIR_TCB_RIGHT_0[13]={
                           0,// CP              = Chain pointer register
                           92,// CC/CL   = Coefficient buffer length register
                           -1,// CM             = Coefficient modifier register
                           coeffs_filt15k+91,   // CI = Cofficient index refister
                           output_filt15kR,// OB       = Ouput data base register
                           1,// OL/OC     = Output buffer length register
                           1,     // OM = Output modifier register
                           output_filt15kR,// OI              = Output data index register
                           input_filt15kR,// IB       = Input data base register
                           92,    // IL/IC = Input buffer length register
                           1,     // IM = Input buffer modifier register
                           input_filt15kR,// II = Input data index register
                           TAPS|WINDOW// IIRCTL= Channel control register, no of TAPS = 92, WINDOW SIZE=1
Void process_audio()
//In_Buf[testCounter] = In_Buf2[testCounter];
       myPointer = FIR_TCB_RIGHT_0[11] | 0x80000;
       //myPointer = TCB_Buf[11] | 0x80000;
       *myPointer = In_Buf2[testCounter];
       /*Selecting FIR accelerator */
       *pPMCTL1&=~(BIT_17|BIT_18);
       *pPMCTL1|=FIRACCSEL;
       /*PMCTL1 effect latency*/
       NOP();NOP();NOP();NOP();
       temp = (TAPS_15k-1);//|WINDOW_15k;
       FIR_TCB_RIGHT_0[12] = temp; /* Value of FIRCTL2;*/
       temp = (int)FIR_TCB_RIGHT_0+12;
       *pCPFIR= temp;
       /* Set the values for FIRCTL1*/
       temp = FIR_CH1|FIR_EN| FIR_DMAEN ;
       *pFIRCTL1 = temp;  /* Enables and runs the DMA*/
       /* Test if the window is processed*/
       while ((*pFIRDMASTAT & FIR_DMAWDONE)==0);
       testBuffer[testCounter]=output_filt15kR[0];
       *pFIRCTL1&=~FIR_DMAEN;
