FMCOMMS1: Clock Genarator adjustments...
Question asked by ehsantelecom on Oct 2, 2014
Latest reply on Nov 2, 2017 by timmy
Hello everybody...
I am using FMCOMMS1 and ZC706 for a project. I need to have 40MHz (and the factors) with maximum precision on the board to sample accurately. I decided to change the crystal oscillator (Y1) from 122.88MHz to 80MHz physically. Now, I have some problems with AD9548 initialization. There are lots of information in the datasheet!
Having minimum amount of changes in the driver, do you have any suggestion? My efforts so far:
I kept 30MHz coming from FPGA to the component and I changed "Free running frequency tuning word" from 0x28f5c28f5c29 to 0x1AAAAAAAAAAB which is not very effective because the output signal is drifting to higher frequencies very rapidly. What other registers should I manipulate?
For the people have not access to the driver's files:
/* System clock settings */
    0,          //sys_clk_ext_loop_filter_en
    0,          //sys_clk_charge_pump_manual_mode_en
    0,          //sys_clk_pll_lock_detect_timer_dis
    0x03,      //sys_clk_charge_pump_current
    0x00,      //sys_clk_pll_lock_detect_timer
    0x28,      //sys_clk_fedback_div
    0,          //sys_clk_m_div
    0,          //sys_clk_2x_mul_en
    1,          //sys_clk_pll_en
    1,          //sys_clk_source
    0x13de43,  //sys_clk_period
    0x000001,  //sys_clk_stability
    /* DPLL Setting */
    0xAA,      //dpll_tunning_word0
    0xAA,      //dpll_tunning_word1
    0xAA,      //dpll_tunning_word2
    0xAA,      //dpll_tunning_word3
    0xAA,      //dpll_tunning_word4
  0x1A,      //dpll_tunning_word5
    0x000000,  //dpll_pull_in_range_limit_low
    0xffffff,  //dpll_pull_in_range_limit_high
    0x00,      //dpll_dds_phase_offset
    0x0000,    //dpll_closed_loop_phase_lock_offset_low
  0x0000,    //dpll_closed_loop_phase_lock_offset_high
    0x03e8,    //dpll_incremental_phase_lock_offset
    0x0000,    //dpll_phase_slew_limit
    0x7530,    //dpll_history_acc_timer
    0x00,      //dpll_history_mode
    30000000,  //dpll_out_freq
    /* Clock distribution synchronization */
    0,          //clock_distr_ext_resistor
    0,          //clock_distr_high_freq_mode
    0x00,      //clock_distr_sync_source
    0x02,      //clock_distr_automatic_sync_mode
    /* General settings */
    0x00,      //watchdog_timer
    0x1ff,      //aux_dac_full_scale_current
    0,          //aux_dac_shutdown
    0x01,      //ref_profile_sel_ssm_startup
    /* Reference profiles */
    0,          //num_ref_profiles
    0,          //ref_profiles
Ehsan
