Questions about ADUM3070
Question asked by Tarzan on Sep 30, 2014
Latest reply on Oct 9, 2014 by bkennedy
I have some questions about ADUM3070.
Since I don't have experience using isolated DC/DC,
It would be great if anyone could give me some advice.
(sorry to ask many questions at the same time)
#1 Question,
I'm trying to calculate Transform ratio by using the following formula
Ns/Np=(Viso+Vd)/(Vdd1min*D*2)
But I don't know what duty cycle should be.
it says  Duty should be 0.3, but I dont where this number come from.
Please advise me on how to estimate duty cycle.
#2 Question,
In order to select Trans inductance, Cout and L1 inductor,
Are there any calculating formulas?
The datasheet recommend value like 400uH for Trans, 47uF for Cout and 100uH/400uH for L1.
Should I use these figures?
Since the output current for my model could be less than 10mA so I'd like to use the smaller capacitor and inductor.
#3 Question,
The datasheet says that it's okay to use 5V to 3.3V for Ns/Np=2.
But I don't think Ns/Np is calculated in 1.2 for 5V to 3.3 V.
Could you make sure if it's correct?
[From page 15]
For a similar 3.3 V input to 3.3 V output, isolated single power
supply and with V DD1 (MIN)  = 3.0 V, the turns ratio is also N S /N P  =
  1. 2. Therefore, the same transformer turns ratio N S /N P  = 2 can be
used for the three single power applications (5 V to 5 V, 5 V to
  1. 3.3 V, and 3.3 V to 3.3 V).
#4 Question,
It looks like the most low power isolated DC/DC incorporate Fryback converter.
But ADUM3070 is push-pull converter(using two FET inside the IC).
I think Flyback can reduce external components like Inductor on the second side.
So I just wonder what is the merit of push-pull converter for the low power isolated DC/DC.
Tarzan
