AD9833 - output failure
Question asked by ICM on Sep 25, 2014
Latest reply on Oct 17, 2014 by musach
I am using DDS AD9833 to give frequency to full bridge inverter (48V).
DDS is drive in SPI.
Decoupling capacitors are not represented on picture.
It works fine but after about 20 hours, output of DDS go to 0 during communication. The current on my inverter increases during this time.
I configure DDS in digital mode : TxDDS2(0x21,0x68);
I have looked communication during the problem : the value sended is right.
01+14 bits LSB, 01+14 bits MSB, 0x20 0x68
or
10+14 bits LSB, 10+14 bits MSB, 0x28 0x68
In yellow: clk
in green: mosi
in violet: Fsync
in red: current in my inverter
The current increase after first trame of data (14bis LSB) and decrease when I validate output.
Same thing but the current increase after second frame:
In yellow:comp
in green:vout
in violet:clk
Frequency vout is 149kHz before communication, 0 during communication, 149kHz after communication.
Do you have a idea to fix this problem?
Is it necessery to place buffers on communication line? Which kind of buffer?
I note that problem occurs more quickly when I place oscilloscope probes on clk or mosi.
