Is this a help file doc error --or is something else going on
Question asked by Brettcoupe on Sep 28, 2010
Latest reply on Oct 1, 2010 by BrettG
Hi
I am using the helpfile implemtation code examples for safeload writes and 5.32 conversion
As Below
Microcontroller Code functions, safeload: single parameter write
void SafeloadSingleParamWrite(short address, float param)
byte param_hex[4] = {0x00, 0x00, 0x00, 0x00};
//convert decimal paramater value to 5.23 format
To523(param, param_hex);
byte paramex_hex[5];
paramex_hex[0]=0x00;
paramex_hex[1]=param_hex[0];
paramex_hex[2]=param_hex[1];
paramex_hex[3]=param_hex[2];
paramex_hex[4]=param_hex[3];
SafeParam(SAFELOAD_DATA_0, paramex_hex);
SafeAddr(SAFELOAD_ADDRESS_0, address);
InitSafeloadParam();
// Microcontroller code - functions: convert a float number to 5.23 format
void To523(float param_dec, byte* param_hex)
long param223;
long param227;
//multiply decimal number by 2^23
param223 = param_dec * (1 << 23);
//convert to positive binary
param227 = param223 + (1 << 27);
param_hex[3]=(byte)param227;  //get byte 3 (LSBs) of parameter value
param_hex[2]=(byte)(param227>>8); //get byte 2 of parameter value
param_hex[1]=(byte)(param227>>16); //get byte 1 of parameter value
//get byte 0 (MSBs) of parameter value
param_hex[0]=(byte)(param227>>24);
//invert sign bit to get correct sign
param_hex[0] = param_hex[0] ^ 0x08;
//Microcontroller Code - functions, Safeload: SafeParam
void SafeParam(short safe_param, unsigned char* param_data)
byte safe_param_lo;
byte safe_param_hi;
//get low byte of register/RAM address
safe_param_lo=(byte)safe_param;
//get high byte of address shift left by 8 bits
safe_param_hi=(byte)(safe_param>>8);
SPI_TX_REG = 0x00; //Write to DSP at chip address 0
SPI_TX_REG = safe_param_hi; //Write high byte of Safeload address
SPI_TX_REG = safe_param_lo; //Write low byte of Safeload address
SPI_TX_REG = param_data[4]; //Write parameter byte 4 (MSBs)
SPI_TX_REG = param_data[3]; //Write parameter byte 3
SPI_TX_REG = param_data[2]; //Write parameter byte 2
SPI_TX_REG = param_data[1]; //Write parameter byte 1
SPI_TX_REG = param_data[0]; //Write parameter byte 1 (LSBs)
NOTE: SPI_TX_REG is replaced with my SPI rutine
SendSPI(param_data[4]) ;      ETC ETC  //Write parameter byte 4 (MSBs)
What I have Found is the the SafeParam() funtion is sending the LSB first Not the MSB as it is said by the comments
if I swap the function to be
SPI_TX_REG = param_data[0]; //Write parameter byte 0 (MSBs)
SPI_TX_REG = param_data[4]; //Write parameter byte 4 (LSBs)
it works Ok.
thoughts?
Thanks
Brett
