SPI reading issue in ADIS16480
Question asked by sayed on Sep 9, 2014
Latest reply on Sep 9, 2014 by NevadaMark
I am using TIVA LM4f232 eval kit to read sensor values from ADIS16480.
While reading through SPI I am able to get correct data only when I am sending twice the read command.
After initialization, when I am sending read command to read the mag-x register value on First iteration ADIS is throwing 0xff in place of actual mag-x value . Only in second time sending of read command, micro-controller able to receive mag-x register value (previous one).
in short, ADIS able to send the data only in second read cycle.
Is there anyway I will receive correct data on same read command.
Below is the part of code that I am using for reading of SPI data:
int read_spi(int32_t i32Char_1)
uint32_t  ulDataRx[NUM_SSI_DATA];
int i=0;
int32_t i32Charp;
int32_t i32Charr;
uint8_t u1DataRx1[4];
uint32_t u1DataRx2[4];
uint32_t u1DataRx3[4];
ulDataRx[0]=0XFFFF;
i32Charp=((i32Char_1)&0xffff0000)>>16;
i32Charr=(i32Char_1)&0x0000ffff;
while(SSIBusy(SSI0_BASE));
     SSIDataPut(SSI0_BASE,i32Charp); //0x8003); // for accessing pageID
      SSIDataPut(SSI0_BASE, i32Charr); //for reading SPI
      SSIDataGetNonBlocking(SSI0_BASE,&u1DataRx2);
      SSIDataGetNonBlocking(SSI0_BASE,&ulDataRx);
            u1DataRx1[0] = (ulDataRx[0]&0x000000ff);
            u1DataRx1[1]= ((ulDataRx[0])&0x0000ff00)>>8;
           u1DataRx1[2]= ((ulDataRx[0])&0x00ff0000)>>16;
           u1DataRx1[3]= ((ulDataRx[0])&0xff000000)>>24;
          USBBufferWrite((tUSBBuffer *)&g_sTxBuffer,(uint8_t *)u1DataRx1, 2);
          USBBufferFlush((tUSBBuffer *)&g_sTxBuffer);
