ADXL345 PMOD Zedboard - Linux Drivers Compile
Question asked by ddub on Sep 3, 2014
Latest reply on Sep 4, 2014 by ddub
Hello all,
I am attempting the tutorial at http://wiki.analog.com/resources/fpga/xilinx/pmod/adxl345 under Linux Device Driver.
I have compiled the kernel as per ADXL345 Input 3-Axis Digital Accelerometer Linux Driver [Analog Devices Wiki] under the heading Adding Linux Driver Support, where in the git/linux directory I type the following:
git checkout xcomm_zynq
export ARCH=arm
export CROSS_COMPILE=arm-xilinx-linux-gnueabi-
make zynq_xcomm_adv7511_defconfig
make menuconfig
In the configuration menu I select
Device Drivers -> Input device support --> Miscellaneous devices --> Analog Devices ADXL34x Three-Axis Digital Accelerometer
I select all three (including support I2C bus connection, SPI bus connection) with * not M.  I then save and exit.
make uImage LOADADDR=0x00008000
I then make the devicetree using the downloaded  zynq-zed-adv7511-pmod-acl.dts and copy the resulting file to the SD card as devicetree.dtb.
I unpack the linaro linux filesystem to the ext4 partition on the SD card.
I copy uImage and the boot.bin file.
I do not see
input: ADXL34x accelerometer as /devices/platform/bfin-spi.1/spi1.2/input/input1
adxl34x spi1.2: ADXL345 accelerometer, irq 140
or anything other than "mice" in /dev/input.
Attached is the kernel boot information.
I using CentOS 6.5 with VMware 5.0.4
