Microblaze program (sometimes) hangs before first DDR memory read in AD9279 design
Question asked by z00345up on Aug 28, 2014
Latest reply on Aug 28, 2014 by rejeesh
I am using the reference design for AD9279 with the ML605 to capture the data and read it back from DDR memory. I have an intermittent problem where the program hangs right before the first memory read. It happens about a third of the time. I am using SDK to program FPGA with the bit/elf files. Below is the slightly modified C code and attached is the system assembly view from XPS.
#include <stdio.h>
#include "platform.h"
#include "xbasic_types.h"
#include "xstatus.h"
#include "xil_io.h"
#include "xparameters.h"
#include "xuartlite_l.h"
#define CF_BASEADDR   XPAR_AXI_ADC_8C_0_BASEADDR
#define DDR_BASEADDR  XPAR_DDR3_SDRAM_S_AXI_BASEADDR
#define DMA_BASEADDR  XPAR_AXI_DMA_0_BASEADDR
#define UART_BASEADDR XPAR_RS232_UART_1_BASEADDR
#define SPI_BASEADDR  XPAR_AXI_SPI_0_BASEADDR
extern char inbyte(void);
void xil_printf(const char *ctrl1, ...);
void delay_ms(u32 ms_count) {
  u32 count;
  for (count = 0; count < ((ms_count * 100000) + 1); count++) {
    asm("nop");
void adc_capture(u32 qwcnt, u32 sa) {
  Xil_Out32((DMA_BASEADDR + 0x030), 0); // clear dma operations
  Xil_Out32((DMA_BASEADDR + 0x030), 1); // enable dma operations
  Xil_Out32((DMA_BASEADDR + 0x048), sa); // capture start address
  Xil_Out32((DMA_BASEADDR + 0x058), (qwcnt * 8)); // number of bytes
  Xil_Out32((CF_BASEADDR + 0x00c), 0x0); // capture disable
  Xil_Out32((CF_BASEADDR + 0x010), 0xfffff); // clear status
  Xil_Out32((CF_BASEADDR + 0x014), 0xfffff); // clear status
  Xil_Out32((CF_BASEADDR + 0x00c), (0x10000 | (qwcnt - 1))); //start capture
  do {delay_ms(1);}
  while ((Xil_In32(CF_BASEADDR + 0x010) & 0x1) == 1); //while status =1
  if ((Xil_In32(CF_BASEADDR + 0x010) & 0x02) == 0x02) { //if overflow =1
    xil_printf("Overflow occurred, capture may be corrupted\n\r");
   microblaze_flush_dcache();
   microblaze_invalidate_dcache();
int main() {
  u32 n,i;
  u32 idata;
  u32 rdata[8] = {0};
  init_platform();
  xil_printf("Platform initialized...\n\n\r");
  xil_printf("Testing ADC read...\n\r");
  if ((Xil_In32(CF_BASEADDR)) == 0x10062) { //if match
     xil_printf("ADC read successful!\n\n\r");
  }else{
     xil_printf("ADC read failed!\n\n\r");
  xil_printf("Starting capture...\n\r");
  adc_capture(16, DDR_BASEADDR);
  delay_ms(10);
  for (n = 0; n < 8; n++) {
   for (i=0; i<4; i++){
  //PROGRAM HANGS HERE
   idata = Xil_In32(DDR_BASEADDR+(n*16)+(i*4));
    rdata[(i*2)] = idata & 0xffff;
    rdata[(i*2)+1] = (idata>>16) & 0xffff;
  for (i=0; i<8; i++){
   xil_printf("%d: %04x\n\r",i,rdata[i]);
  xil_printf("Done... Exiting program.\n\r");
  cleanup_platform();
  return 0;
