ADAU1761 grounding
Question asked by bootload on Sep 20, 2010
Latest reply on Sep 13, 2011 by BrettG
From the data sheet I read:
NOTES
1. THE EXPOSED PAD IS CONNECTED INTERNALLY TO THE
   ADAU1761 GROUNDS. FOR INCREASED RELIABILITY OF THE
   SOLDER JOINTS AND MAXIMUM THERMAL CAPABILITY, IT IS
   RECOMMENDED THAT THE PAD BE SOLDERED TO THE
   GROUND PLANE.
I am planning to have a split ground plane. I would typically tie the the DGND
and AGND together at one point (through a low ohm resistor). Is the data sheet
saying that the two AGNDs and the DGND are tied internally to the exposed pad?
It was my intent to have the copper rectangles under the device tied to AGND plane
and then have the DGND connection go to the single connection point. Would this
create a ground loop?
Thanks
