kernal cannot mount rootfs when bootm vmImage
Question asked by jiangfux on Aug 22, 2014
Latest reply on Aug 24, 2014 by jiangfux
If i bootm vmImage, kernel cannot mount rootfs. both ubifs and jffs2 are failured.
buildroot : blackfin-buildroot-2014R1-RC1.tar.bz2
toolchain :blackfin-toolchain-uclibc-full-2014R1-RC2.i386
               blackfin-toolchain-elf-gcc-4.3-2014R1-RC2.i386
               blackfin-toolchain-2014R1-RC2.i386
after unpack buildroot,
[root@localhost blackfin-buildroot]$ make bf609-ezkit_defconfig
[root@localhost blackfin-buildroot]$ make linux-menuconfig
and change JFFS2 compile into kernal(not as a module).
[root@localhost blackfin-buildroot]$ cp output/images/vmImage /var/lib/tftpboot
on my board,
bfin> tftp 1000000 vmImage
Waiting for PHY auto negotiation to complete done
ENET Speed is 100 Mbps - FULL duplex connection
Using mii0 device
TFTP from server 192.168.2.16; our IP address is 192.168.2.17
Filename 'vmImage'.
Load address: 0x1000000
Loading: #################################################################
done
Bytes transferred = 1667560 (1971e8 hex)
bfin> bootm
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf609-0.0-3.10.10-ADI-2014R1
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    1667496 Bytes = 1.6 MiB
   Load Address: 00001000
   Entry Point:  002e5990
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 002e5990
Linux version 3.10.10-ADI-2014R1 (root@localhost.localdomain) (gcc version 4.3.5 (ADI-2014R1-RC2) ) #3 Fri Aug 22 23:33:05 CST 2014
register early platform devices
bootconsole [early_shadow0] enabled
ERROR: Not running on ADSP-BF609: unknown CPUID 0x0000 Rev 0.0
bootconsole [early_BFuart0] enabled
early printk enabled on early_BFuart0
Board Memory: 128MB
Kernel Managed Memory: 128MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x001f7788
  rodata    = 0x001f77ac-0x002a16c0
  bss       = 0x002a2000-0x002b7ddc
  data      = 0x002b7de0-0x002e2000
    stack   = 0x002e0000-0x002e2000
  init      = 0x002e2000-0x00301000
  available = 0x00301000-0x07f00000
  DMA Zone  = 0x07f00000-0x08000000
Hardware Trace active and enabled
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF609 Rev 0.0
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 500 MHz core clock, 125 MHz SCLk, 125 MHz SCLK0, 125 MHz SCLK1 and 250 MHz DCLK
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
  L2 SRAM        : uncacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-back) in data cache
  L2 SRAM        : uncacheable in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 32258
Kernel command line: root=/dev/mtdblock0 rw clkin_hz=(25000000) earlyprintk=serial,uart0,57600 console=ttyBF0,57600
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Sorting __ex_table...
Memory available: 125804k/131072k RAM, (124k init code, 2009k kernel code, 939k data, 1024k dma, 1172k reserved)
NR_IRQS:291
Configuring Blackfin Priority Driven Interrupts
Console: colour dummy device 80x25
Calibrating delay loop... 989.18 BogoMIPS (lpj=1978368)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
devtmpfs: initialized
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (9 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 64 KB (51 KB free)
Blackfin L2 SRAM: 256 KB (256 KB free)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c-bfin-twi i2c-bfin-twi.0: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01e00
i2c-bfin-twi i2c-bfin-twi.1: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01f00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
NET: Registered protocol family 23
Switching to clocksource bfin_cs_cycles
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 245
io scheduler noop registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc02000 (irq = 88) is a BFIN-UART
console [ttyBF0] enabled, bootconsole disabled
physmap platform flash device: 01000000 at b0000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x008821
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
Creating 3 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000080000 : "bootloader(nor)"
0x000000080000-0x000000480000 : "linux kernel(nor)"
0x000000480000-0x000001000000 : "file system(nor)"
m25p80 spi0.67: w25q32 (4096 Kbytes)
Creating 3 MTD partitions on "m25p80":
0x000000000000-0x000000080000 : "bootloader(spi)"
0x000000080000-0x000000200000 : "linux kernel(spi)"
0x000000200000-0x000000400000 : "file system(spi)"
CAN device driver interface
bfin_can bfin_can.0: bfin_can device registered(&reg_base=ffc00a00, rx_irq=47, tx_irq=48, err_irq=49, sclk=125000000)
stmmac - user ID: 0x10, Synopsys ID: 0x36
Enhanced/Alternate descriptors
        Enabled extended descriptors
Ring mode enabled
DMA HW capability register supported
RX Checksum Offload Engine supported (type 2)
Wake-Up On Lan supported
Enable RX Mitigation via HW Watchdog Timer
libphy: stmmac: probed
eth0: PHY ID 20005c90 at 1 IRQ 0 (stmmac-0:01) active
usbcore: registered new interface driver usb-storage
input: bfin-rotary as /devices/platform/bfin-rotary/input/input0
i2c /dev entries driver
bfin_wdt: initialized: timeout=20 sec (nowayout=0)
dma_alloc_init: dma_page @ 0x041a8000 - 256 pages at 0x07f00000
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Warning: unable to open an initial console.
VFS: Cannot open root device "mtdblock0" or unknown-block(31,0): error -2
Please append a correct "root=" boot option; here are the available partitions:
1f00             512 mtdblock0  (driver?)
1f01            4096 mtdblock1  (driver?)
1f02           11776 mtdblock2  (driver?)
1f03             512 mtdblock3  (driver?)
1f04            1536 mtdblock4  (driver?)
1f05            2048 mtdblock5  (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)
Hardware Trace:
   0 Target : <0x001f7338> { _dump_stack + 0x0 }
     Source : <0x001f73e6> { _panic + 0x6a } CALL pcrel
   1 Target : <0x001f73d4> { _panic + 0x58 }
     Source : <0x0000a8a6> { _test_taint + 0x2a } RTS
   2 Target : <0x0000a87c> { _test_taint + 0x0 }
     Source : <0x001f73d0> { _panic + 0x54 } JUMP.L
   3 Target : <0x001f73ce> { _panic + 0x52 }
     Source : <0x001f7596> { _printk + 0x26 } RTS
   4 Target : <0x001f7592> { _printk + 0x22 }
     Source : <0x0000c9aa> { _vprintk_emit + 0x11e } RTS
   5 Target : <0x0000c9a2> { _vprintk_emit + 0x116 }
     Source : <0x0000c994> { _vprintk_emit + 0x108 } IF CC JUMP pcrel (BP)
   6 Target : <0x0000c990> { _vprintk_emit + 0x104 }
     Source : <0x0000ca70> { _vprintk_emit + 0x1e4 } JUMP.S
   7 Target : <0x0000ca70> { _vprintk_emit + 0x1e4 }
     Source : <0x0000c07e> { _console_unlock + 0x18a } RTS
   8 Target : <0x0000c078> { _console_unlock + 0x184 }
     Source : <0x0000be8a> { _wake_up_klogd + 0x36 } RTS
   9 Target : <0x0000be86> { _wake_up_klogd + 0x32 }
     Source : <0x0000be64> { _wake_up_klogd + 0x10 } IF CC JUMP pcrel
  10 Target : <0x0000be54> { _wake_up_klogd + 0x0 }
     Source : <0x0000c074> { _console_unlock + 0x180 } JUMP.L
  11 Target : <0x0000c06c> { _console_unlock + 0x178 }
     Source : <0x0000c232> { _console_unlock + 0x33e } JUMP.S
  12 Target : <0x0000c22e> { _console_unlock + 0x33a }
     Source : <0x0000c062> { _console_unlock + 0x16e } IF CC JUMP pcrel
  13 Target : <0x0000c060> { _console_unlock + 0x16c }
     Source : <0x0000c052> { _console_unlock + 0x15e } IF CC JUMP pcrel (BP)
  14 Target : <0x0000c044> { _console_unlock + 0x150 }
     Source : <0x00025402> { _up + 0x36 } RTS
  15 Target : <0x000253fc> { _up + 0x30 }
     Source : <0x000253ee> { _up + 0x22 } IF CC JUMP pcrel (BP)
CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.10-ADI-2014R1 #3
Stack info:
SP: [0x04025ddc] <0x04025ddc> /* kernel dynamic memory (maybe user-space) */
Memory from 0x04025dd0 to 04026000
04025dd0: 00000000  04025ddc  00000000 [00000000] 04025e00  001f73ea  041b0000  00249c98
04025df0: 002f63cc  002a60f0  00000013  04025e28  04025e58  002e2a1c  041b0000  041b0000
04025e10: 002f63cc  04025e38  fffffffe  00386600  00249d00  00000000  04025e38  00000001
04025e30: fffffffe  00000000  6e6b6e75  2d6e776f  636f6c62  3133286b  0029302c  002f5f5c
04025e50: 00249d00  00249d00  04025e88  002e2b62  002a2064  002f6388  002f5f5c  01f00000
04025e70: 00249d00  00000050  002e229c  04025e90  002e2d2a  002e2c20  04025eac  002e2c6e
04025e90: 00000008  002a2010  00000008  002a2010  00000050  002e229c  00000000  04025ed8
04025eb0: 002e2276  002fbe7c  002f5f80  00249bc4  04045000  00000000  00000050  00000007
04025ed0: 00000007  002e229c  04025f08  001f6502  002ad584  04023d60  04023ac0  04023c14
04025ef0: 002c2f74  002c2ec8  0402c000  0402deb0  ffa00006  002ad584  0402deb0 <ffa00014>
04025f10: 002ad584  04023d60  9000a314  001f64f8  00000000  00000000  00008000  00000000
04025f30: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
04025f50: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
04025f70: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
04025f90: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
04025fb0: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
04025fd0: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
04025ff0: 00000000  00000000  ffffffff  00002806
Return addresses in stack:
    address : <0xffa00014> { _ret_from_fork + 0x14 }
After a lot of work on this error, i got some information.
patch attachment to linux-kernel,  when bootm vmImage,
kernel log is
bfin> bootm
Board Memory: 128MB
Memory map:
NR_IRQS:291
Ring mode enabled
kern_path return -2, dir_name = /root
Hardware Trace:
Stack info:
04025f10: 002ad584  04023d60  8200a310  001f64f8  00000000  00000000  00008000  00000000
when kernel mount rootfs in do_mount,
kern_path can not find directory "/root", and return -2(ENOENT).
please help me, thanks.
