Trying to build zc706 zynq / ad9361 kernel / libiio examples
Question asked by John-Morris on Aug 18, 2014
Latest reply on Aug 19, 2014 by larsc
I'm new to zynq and ad9361 and still finding my way around - please be patient while I learn!
The example code in libiio/examples/ad9361-iiostream.c looks to be quite a good start point for what I need to do. It all compiled ok, but when run it fails with this:
* Initializing AD9361 IIO streaming channels
ad9361-iiostream: ad9361-iiostream.c:206: main: Assertion `get_ad9361_stream_ch(ctx, TX, tx, 0, &tx0_i) && "TX chan i not found"' failed.
Digging in, it's looking for a Tx "out_voltage" channel on iio device 3 (the DAC), but there are only "out_altvoltage" channels available according to /sys. Trying to debug this was hard because the system came with Linux 3.13 but the source in github is 3.14. The 3.14 source looked as though it should provide those "out_volatge" channels, so I decided to try a later kernel.
So I followed the procedure at Zynq and the AD9361 and/or AD9364 [Analog Devices Wiki] to build an up to date kernel and device tree blob. The resulting kernel hangs during boot. The last few lines on the serial console are:
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0018000
[drm] Initialized drm 1.1.0 20060810
drivers/gpu/drm/adi_axi_hdmi/axi_hdmi_drv.c:axi_hdmi_platform_probe[176]
platform 70e00000.axi_hdmi: Driver axi-hdmi requests probe deferral
brd: module loaded
loop: module loaded
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
zynq-ehci zynq-ehci.0: Xilinx Zynq USB EHCI Host Controller
zynq-ehci zynq-ehci.0: new USB bus registered, assigned bus number 1
zynq-ehci zynq-ehci.0: irq 53, io mem 0x00000000
zynq-ehci zynq-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
adv7511 0-0039: Failed to write 98 = 3: -5
adv7511: probe of 0-0039 failed with error -5
And there it stops.
The system is partly alive - if I plug/unplug USB devices the appropriate messages appear on the serial console - but the system never reaches the command line prompt.
I did not update the boot code or the FPGA code (another issue: the published hdl won't build in the latest Xilinx Vivado) , so I'm wondering if the newly built dtb has a mismatch with the older FPGA config.
Any pointers would be appreciated.
John Morris.
