SPI slave select in Software control
Question asked by ANANDSM on Aug 18, 2014
Latest reply on Oct 13, 2014 by ANANDSM
Hi All,
I am using the ADSP-BF538F processor. I am configuring the SPI2 in master mode in CCES 1.1.0 IDE.
I want to use the SPI2 slave select SPI2SEL1  in user software control and the configuration is shown below.
could you please let me know, whether I need to  configure the pin related to SPI2SEL1  as GPIO (PD9) and control its logic level through GPIO API?
Please guide me on this.
/* flag indicating the is a SPI transceiver available */
    static bool bAvailable = false;
    /* pointer to store transceiver */
    ADI_SPI_TRANSCEIVER *pTrans;
    /* SPI driver handle */
    ADI_SPI_HANDLE hSPI2Device;
    /* SPI driver memory */
    uint8_t driverMemory[ADI_SPI_INT_MEMORY_SIZE];
    /* driver API result code */
  ADI_SPI_RESULT result;
    /* open the SPI driver */
    result = adi_spi_Open(2, driverMemory, (uint32_t)ADI_SPI_DMA_MEMORY_SIZE, &hSPI2Device);
    /* Using the driver API's to configure SPI
     * Setting the SPI2 as Master*/
    result = adi_spi_SetMaster(hSPI2Device, true);
    /* Setting the slave select through software*/
    result = adi_spi_SetHwSlaveSelect(hSPI2Device, false);
    /* Use SSEL1 as slave select pin*/
   result = adi_spi_SetSlaveSelect(hSPI2Device, ADI_SPI_SSEL_ENABLE1);
    /* Setting the data word lenght as 8 bit*/
    result = adi_spi_SetWordSize(hSPI2Device, ADI_SPI_TRANSFER_8BIT);
    /* Setting the SCLK frequency to 20MHz */
    result = adi_spi_SetClock(hSPI2Device, 20);
Thank you very much in advance.
Looking forward to hear from you soon.
Regards
Anand M
