AD7606 Driver requests probe deferral.
Question asked by simba on Aug 16, 2014
Latest reply on Aug 18, 2014 by simba
I am trying to register AD7606 as a SPI platform driver for Intel Galileo board. Kernel 3.8. I have included the AD7606 driver in the kernel build as a built in package, so it tries registering during boot time.
Below is the logs showing errors.
It fails to allocate gpio for CONVST, though it's found to be a valid gpio.
Any Idea what might be the issue, or how I can go about debugging this problem.
Regards
Simba
mount: devtmpfs is already mounted or /dev busy
Starting udev
[    9.858963] udevd[985]: starting version 182
[   11.195458] ce4100_spi 0000:00:15.0: enabling device (0000 -> 0002)
[   11.285409] ce4100_spi 0000:00:15.1: enabling device (0000 -> 0002)
[   11.370247] AD7606: Allocating INT gpio line.  // This I have added to get irq for BUSY line before SPI calls register.
[   11.374712] platform qrk-gpio-restrict-sc.0: Driver qrk-gpio-restrict-sc requests probe deferral
[   11.595100] intel_qrk_gpio_probe UIO addr 0x90006000 internal_addr 0xe067c000 size 4096 memtype 1
[   11.656611] intel_qrk_gip 0000:00:15.2: i2c speed set to 100kHz
[   13.220210] spi_master spi0: will run message pump with realtime priority
[   13.265616] spi_master spi1: will run message pump with realtime priority
[   13.294899] cy8c9540a 0-0020: dev_id=0x40
[   13.379974] ad7606 spi1.1: failed to request GPIO CONVST 27 : -517
[   13.388289] spi spi1.1: Driver ad7606 requests probe deferral
[   13.395586] ad7606 spi1.1: failed to request GPIO CONVST 27 : -517
[   13.423829] spi spi1.1: Driver ad7606 requests probe deferral
[   13.457204] at24 0-0050: byte_len looks suspicious (no power of 2)!
[   13.482705] at24 0-0050: 11264 byte at24 EEPROM, writable, 1 bytes/write
[   13.504827] industrialio: exports duplicate symbol iio_buffer_init (owned by kernel)
[   13.518263] ------------[ cut here ]------------
[   13.523052] WARNING: at /home/vikram/Galileo/meta-clanton_v1.0.0/yocto_build/tmp/work/clanton-poky-linux/linux-yocto-clanton/3.8-r0/linux/drivers/gpio/gpiolib.c:1921 __gpio_set_value+0x8d/0xa0()
[   13.540486] Hardware name: QUARK
[   13.543744] Modules linked in: at24(+) cy8c9540a spi_pxa2xx gpio_sch intel_qrk_gip uio spi_pxa2xx_pci evdev mmc_block ehci_pci ohci_hcd ehci_hcd sdhci_pci sdhci usbcore led_class stmmac usb_common mmc_core
[   13.562516] Pid: 768, comm: kworker/u:2 Not tainted 3.8.7-yocto-standard #5
[   13.569513] Call Trace:
[   13.572095]  [<c1029d2d>] warn_slowpath_common+0x6d/0xa0
[   13.577475]  [<c116270d>] ? __gpio_set_value+0x8d/0xa0
[   13.582753]  [<c116270d>] ? __gpio_set_value+0x8d/0xa0
[   13.587962]  [<c1029d7d>] warn_slowpath_null+0x1d/0x20
[   13.593244]  [<c116270d>] __gpio_set_value+0x8d/0xa0
[   13.598270]  [<c123273d>] ad7606_reset+0x1d/0x50
[   13.603033]  [<c1232c8c>] ad7606_probe+0x29c/0x4c0
[   13.607891]  [<c10f4563>] ? sysfs_do_create_link+0xa3/0x1c0
[   13.613610]  [<c123328b>] ad7606_spi_probe+0x2b/0x50
[   13.618634]  [<c12124f5>] spi_drv_probe+0x15/0x20
[   13.623478]  [<c11e6566>] driver_probe_device+0x56/0x1e0
[   13.628853]  [<c121321a>] ? spi_match_device+0x3a/0x90
[   13.634130]  [<c11e6780>] ? __driver_attach+0x90/0x90
[   13.639237]  [<c11e67b9>] __device_attach+0x39/0x50
[   13.644264]  [<c11e4eb4>] bus_for_each_drv+0x34/0x70
[   13.649290]  [<c11e64db>] device_attach+0x7b/0x90
[   13.654128]  [<c11e6780>] ? __driver_attach+0x90/0x90
[   13.659239]  [<c11e5b87>] bus_probe_device+0x67/0x90
[   13.664339]  [<c11e5feb>] deferred_probe_work_func+0x5b/0x90
[   13.670135]  [<c103db1e>] process_one_work+0x10e/0x370
[   13.675340]  [<c103e9f1>] worker_thread+0x101/0x330
[   13.680365]  [<c103e8f0>] ? busy_worker_rebind_fn+0xb0/0xb0
[   13.686010]  [<c104248e>] kthread+0x8e/0xa0
[   13.690353]  [<c12c907b>] ret_from_kernel_thread+0x1b/0x30
[   13.695916]  [<c1042400>] ? kthread_create_on_node+0xa0/0xa0
[   13.701702] ---[ end trace f8c04f99418da205 ]---
[   13.743350] industrialio: exports duplicate symbol iio_buffer_init (owned by kernel)
[   13.768764] ------------[ cut here ]------------
[   13.773552] WARNING: at /home/vikram/Galileo/meta-clanton_v1.0.0/yocto_build/tmp/work/clanton-poky-linux/linux-yocto-clanton/3.8-r0/linux/drivers/gpio/gpiolib.c:1921 __gpio_set_value+0x8d/0xa0()
[   13.791000] Hardware name: QUARK
[   13.794261] Modules linked in: at24 cy8c9540a spi_pxa2xx gpio_sch intel_qrk_gip uio spi_pxa2xx_pci evdev mmc_block ehci_pci ohci_hcd ehci_hcd sdhci_pci sdhci usbcore led_class stmmac usb_common mmc_core
[   13.812768] Pid: 768, comm: kworker/u:2 Tainted: G        W    3.8.7-yocto-standard #5
[   13.820784] Call Trace:
[   13.823309]  [<c1029d2d>] warn_slowpath_common+0x6d/0xa0
[   13.828682]  [<c116270d>] ? __gpio_set_value+0x8d/0xa0
[   13.833958]  [<c116270d>] ? __gpio_set_value+0x8d/0xa0
[   13.839167]  [<c1029d7d>] warn_slowpath_null+0x1d/0x20
[   13.844445]  [<c116270d>] __gpio_set_value+0x8d/0xa0
[   13.849470]  [<c1232754>] ad7606_reset+0x34/0x50
[   13.854219]  [<c1232c8c>] ad7606_probe+0x29c/0x4c0
[   13.859075]  [<c10f4563>] ? sysfs_do_create_link+0xa3/0x1c0
[   13.864787]  [<c123328b>] ad7606_spi_probe+0x2b/0x50
[   13.869812]  [<c12124f5>] spi_drv_probe+0x15/0x20
[   13.874647]  [<c11e6566>] driver_probe_device+0x56/0x1e0
[   13.880022]  [<c121321a>] ? spi_match_device+0x3a/0x90
[   13.885293]  [<c11e6780>] ? __driver_attach+0x90/0x90
[   13.890476]  [<c11e67b9>] __device_attach+0x39/0x50
[   13.895431]  [<c11e4eb4>] bus_for_each_drv+0x34/0x70
[   13.900529]  [<c11e64db>] device_attach+0x7b/0x90
[   13.905288]  [<c11e6780>] ? __driver_attach+0x90/0x90
[   13.910468]  [<c11e5b87>] bus_probe_device+0x67/0x90
[   13.915490]  [<c11e5feb>] deferred_probe_work_func+0x5b/0x90
[   13.921285]  [<c103db1e>] process_one_work+0x10e/0x370
[   13.926490]  [<c103e9f1>] worker_thread+0x101/0x330
[   13.931510]  [<c103e8f0>] ? busy_worker_rebind_fn+0xb0/0xb0
[   13.937156]  [<c104248e>] kthread+0x8e/0xa0
[   13.941492]  [<c12c907b>] ret_from_kernel_thread+0x1b/0x30
[   13.947055]  [<c1042400>] ? kthread_create_on_node+0xa0/0xa0
[   13.952835] ---[ end trace f8c04f99418da206 ]---
[   13.965970] ad7606: probe of spi1.1 failed with error -22
[   14.084283] EFI Variables Facility v0.08 2004-May-17
Starting Bootlog daemon: bootlogd.
